Ok, I just got a new piece of the original motor cover for my Cube, and instead of ordering a StandUp plate to give it more protection, I decided to implement my own DIY plate under it! I used 10€ to buy a 5mm thick PE300 plastic plate at size 500mm x 300mm, cut it into correct size with iron saw & dremel, drilled 8 holes onto it, bent it with a hot air blower, and put it into place with eight pop rivets.
I convinced that NOTHING is able to break that PE 300 plate when used on e-bike, since that same material is used for skid plate material for motorcycles, all-terrain vehicles and even for cars. But to be honest, I'm not quite sure if those pop rivets are strong enough to hold the plate in it's place if I hit the rock hard enough, but I also think that it doesn't actually matter. If it just takes the hit and drops off, I can always easily put it back in 15 minutes. Or maybe I'll get some thicker pop rivets, or even try bolts & nuts, that should hold it place for sure?. ( As you can see from the pictures, I ran out of correct size spacers, but let's see if the pop rivets hold anyway...?
This was actually quite simple to implement, it did not even take an hour and it was ready and installed. And I also think that it looks quite nice, doesn't draw too much attention.
What's your opinion, should this give enough protection to keep the original cover in one piece..? I will of course keep you updated, after I get a few contacts with those bloody rocks :=)
