Unanswered Quick link removal tool
Roger20
138
96
West Yorkshire UK
I use one of these at home but it's too big to carry in a saddlepack. What do you guys use to get a quick link apart on the trail because they can be very tight, even using this tool.
RickBullotta
1,783
1,522
Curious question: why would you ever need to do this? If you have a perfectly good link, leave it. Just carry a second quick link if you break your chain. No tool needed to install the link.
Roger20
138
96
West Yorkshire UK
Sometimes derailleurs break or a chain gets tangled and twists badly - we've seen all sorts of things happen on group rides over the years. Carrying a few extra links and quick links has stopped someone being stranded a long way from home.
Konanige
422
336
Mendips
I must agree, in my 35 years of riding on and mostly off road I have never ever encountered a situation that required undoing a quick chain link. I can understand having to put a chain back together on a ride so carry a spare always.
8,720
I have never had to undo one on the trail either, because I too carry spares. However, when I first read that they could be undone with string I thought I'd try it in the comfort of my garage. I much prefer the specialist tool featured in the OP, but I don't bother carrying it in my pack.
PS: The pliers have an irritating habit of throwing the spring, so I have secured it with a small zip tie that goes around the handle and through the coil in the spring. That means that when it does come off it stays attached to the pliers instead of pinging half way across the garage.
RickBullotta
1,783
1,522
Yup. But never I have seen that require removal of a quick link. Removing links and installing another quick link, definitely. I guess my point is that it's not worth carrying the particular tool (quick link removal). I always carry a chain breaker though.
6,174
4,696
I just carry with me on rides a spare chain already cut to size plus a couple of quicklinks.
If you want to break a quicklink and do not have the tool any strong piece of string or wire will do using an allen key or similar to twist it like a tourniquet..............or a zip tie will often do it.
526K
