Venlo
I've got an alloy 2019 large levo. Don't know if that's a problem with the internal welds. What's the lowest you can instal the reverb? I need 235 mm measured from the middle of the saddle rail to the upperside of the collar
I have a 2021 Levo alloy and have the 175mm dropper Reverb AXS and it bottoms out, so plenty of room.I've got an alloy 2019 large levo. Don't know if that's a problem with the internal welds. What's the lowest you can instal the reverb? I need 235 mm measured from the middle of the saddle rail to the upperside of the collar
Did you also buy the 30.9 mm reverb?I have a 2021 Levo alloy and have the 175mm dropper Reverb AXS and it bottoms out, so plenty of room.
My AXS reverb came from my old Intense Tazer which is 31.6mm.Did you also buy the 30.9 mm reverb?
Works the same as wired so yes it does require input from the rider. I love it & dont think I would ever go back to wired?Question: Does the dropper drop dwon with it's own weight when pushing the button or do you have to press it down like the normal ones?
Works the same as wired so yes it does require input from the rider. I love it & dont think I would ever go back to wired?![]()
You've to press it down like a normal dropper.Question: Does the dropper drop dwon with it's own weight when pushing the button or do you have to press it down like the normal ones?
I put a 150 in my Levo medium and there was plenty of room & reckon I could have gone for a 170:@Kiwi in Wales did you get the 170 AXS reverb? Are you able to slam it in the medium Levo?
Looking to do the same, any info either way is appreciated.
Yeah, I have the 150mm command post now, with around 1.5 inches of the post exposed below the bottom of the collar - I think it’s going to be pretty close for the 170mm but would like to get it if possible (assuming tire clearance doesn’t become an issue)I put a 150 in my Levo medium and there was plenty of room & reckon I could have gone for a 170:. Bit late now & don't feel like putting in the $ for the extra 20 mm although it would def be of benefit.
Suppose a big part is how long your legs are? As to how high up your post is out of the seat tube
