I know, that's why I went for a Jade X.DVO Jade won‘t fit a large rail
60mm - 156mm
62.5mm - 163mm
65mm - 169mm
Most metric shocks start life as 205x65mm & travel is reduced either internally or externally with travel reducing spacers. I'm not sure many 65mm decent shocks with a piggyback will fit due to downtube interference towards the end of the stroke. The TTX with the sideways reservoir will, not sure if the JadeX will, possibly the new '21 DHX2 as it has a smaller, offset piggyback. I can get ~61mm stroke out of a mutant EXT Arma/Storia I had converted which is +/-159mm rear wheel travel, which works for me.
Also worth considering due to the way the rocker link moves, the shock goes forward in it's first part of travel, there is a chance it will come into contact with your bottle/cage if you are running one.
Has anyone fitted a DPX2 to a Trek Rail 9? Wondering if I would just need the same size mounts as you used zaykay? The Rockshox rear shock failed after 3 rides. Loosing air and leaking oil.
What year is it mate as I might be bidding on a 2019 mobile just wondering if there was a differenceGot finally the mounting hw for my coil shock. Two alternatives to install DHX2, either use 10 x 40 and 10 x 54 Fox mounting kits or press 12,7mm du bushings and use the stock shocks mounting hw. Both will work.View attachment 24335
DVO Jade X on a Medium Rail 7
Plenty of clearance, just waiting for a spring now.
Different part numbers so most likely different lengths... Thanks
Could the Marzocchi Bomber CR be used in place of the DHX2?Got finally the mounting hw for my coil shock. Two alternatives to install DHX2, either use 10 x 40 and 10 x 54 Fox mounting kits or press 12,7mm du bushings and use the stock shocks mounting hw. Both will work.View attachment 24335
Mine is 2018 DHX2 60mm strokeWhat year is it mate as I might be bidding on a 2019 mobile just wondering if there was a difference
I’m skeptical. It has bigger reservoir tilted more forward. Most propably hits the downtube.Could the Marzocchi Bomber CR be used in place of the DHX2?
Yeah doesn't look like it will work.. BummerI’m skeptical. It has bigger reservoir tilted more forward. Most propably hits the downtube.
A friend has a Bomber CR in a large. Fits!Could the Marzocchi Bomber CR be used in place of the DHX2?
Thanks. But I percieve the problem is not just at the end, but the last half of the stroke. Maybe I will give it a try.Try progressive springs... Mrp progressive or Cane creek progressive valt...
I'm beginning to have doubt's about coil shocks.
Does anyone find that the DHX2 bottoms out too easily? I have have been experimenting with different springs and still think the shock goes through the travel too fast. I'm about 87 kg fully equipped. I started with a 450 spring. That was obviously too light. So I tried the 475. And then the 500. It helped some, but it still felt like the shock had too little reserves on rough/fast stuff. So much that it made me slower. So then i tried the 550. And it still bottoms out on 70cm drops. It rides higher in it's travel and feels more composed on rougher terrain, but now some of the "smooth coil feel" starts to get away. This is very noticeable while climbing. With the softer springs, I could just sit and comfortably pedal over stuff, but now with the 550 spring it starts to feel like the air shock.
I need to experiment more with HSC/LSC, but I'm starting to wonder if I'd be better served with an X2. There might be a reason as to why the pro's don't all go coil shock.
Are you hucking to flat or to a transition to get it to bottom out? And either way, with no offense meant, are you finessing the drop or just ploughing over it? That will make a huge difference to how the bike handles the landing.still bottoms out on 70cm drops
RRP front standard for both f/r@Leo76dragon - what are these nice fenders?
