Knock block snapped
MsO
swindon
Had a little fall on the rail 7 today heard a snapping sound now bars turn all the way round no noise coming from them and a nice smooth action when I turn them shall I just leave it as it is or do I need to take it apart
Lol seems to be bars turn nice and smoothly nothing hits but don't no where the bit that snapped off is going to a local bike park today so hopefully all should be ok
I just created an account to post this.
You should remove your fork along with the small knock block piece that screws in to the frame and very, very carefully check the frame. It's entirely possible that you may have cracked the frame.
I have seen this before, see the attached picture of frame that was warrantied after cracking.
During a crash, the knock block can transfer all of the energy into a small area and crack the frame.
But I'll check again and do what you mentioned just had a new frame fitted as well for the battery alignment
You would need to remove the fork and the knock block adapter that screws onto the frame to check. The picture above is just one example that was very obvious. Otherwise if there is no crack in the frame count yourself lucky.
In these instances warranty claims have been denied as a crack in this area is indicative of "crash damage and/or misuse"
    675K
