New Tire for 27.5 Decoy. Anyone using a less wide rear tire.
See post #69 (R120) ... Larry Enticer would be proud
EST 5mm difference
FWIW .. you will get used to the pedal strikes ... took me 2 months to adapt, but I rarely strike now (*after destroying a set of flat pedals when the bike was new) :)
It comes down to riding style when choosing high or low BB (I am a low rider). The 2.6 tire in high bb setting would give similar feel .. but still a lot of pedal strikes to get used to (do not worry .. you will get used to it either way ... especially if this is your first e-bike)
Yeah that brought me to my next question reference flipping the shock it into the high settings. Do you have any noticeable difference in the seat angle? I really wish I went for an XL and not an L. With the really steep STA and the really short steerer tube I feel like I’m right over the bars. I got a new fork and I’m hoping it’ll fix that some. It’s my second ebike. I still have my 15’ Haibike Xduro Nduro which the BB sits really high off the ground. It’s. 26”, medium, 180 F/R and sits higher then my Decoy. If it’s only a roughly 5mm drop then 2.6 might be next for me!
Best bet is purchase a cheep track pump with no gauge and buy a digital tire pressure gauge. Monitor air pressure for performance , adjust and check tire pressure every ride.
Agreed.
I also just purchased the SKS Aircheck (because I'm a data geek) which provides useful real time info. I have it synced to my Garmin Edge and can follow PSI changes throughout the ride.
Looking to replace my current OEM 2.8 rear Maxxis. Anyone having luck with a less wide, same width with a different tire brand altogether? Who is having better luck with their new choice or tire?
I am running a 2.6 Schwalbe Eddy Current and it's been great.
    674K
