Trek Rail 5 2020 - Rearhub service
Hamina
FIN
After 500km the rearhub of my Rail 5 seems to come to an end. Problems started when chain started to drop off from front sprocket.
OEM SRAM SX chain was at 0,5% -> replaced with GX chain.
OEM SRAM SX cassette was missing one tooth -> replaced with new SRAM NX cassette.
With new (and old) NX cassette there seems to be play in the driver/freehub. When driving in biggest gear with quite normal pedal pressure the freehub seems to pop-off one teeth forward (I don't know the correct word in english). I think it might have to do with the play and the fact that torque from smallest cog causes pawls loose the grip.
Trak Rail 5 hub specs:
Freehub/Driver: Formula DWG--137
Driverside: Xero 15267 LU 15x26x7mm
Non-Driverside: Xero 6902-LU 15x28x7
The inner diameter is 29,5mm if you want to build your own tool from socket.
Play:
Some instructions how to disassemble the hub:
Hi Lo rear disc hub service/replacement- Mtbr.com (bearings are different)
Potential spareparts:
COMMENCAL | HUB AXLE KIT FORMULA AX-2139 the hub axle
Free hub bodies - Shop One of these could fit
I'll try to fix it by changing new bearings and report back. I'll add some photos when I get the freehub open.
Removed one thin shim inside the freehub and handtightened the freehub. Play seems to go away. Washed everything with IPA and put new grease inside.
Made a tool from 21mm socket
This is what's inside. 3 shims: 2 thins + 1 thick.
The freewheel pawls. Seems to be ok
My rear hub on my Rail 5 had been making a rough noise for a while. I asked my LBS to have a look while they were looking at my gears and updating the firmware.
They changed the bearings in my rear hub. Its come back super quiet. I've attached a picture of the parts that were removed with the invoice.
Don't know if this helps anyone.
Bought a new OEM freehub. Seems to function correctly but there’s still aldready little play when pushing cassette on sides. Interesting to see how long it last. Hopefully until I get some decent hubs and rims.
Changed also the other bearing (6902), but only because I accidentally broke it.
W547627 is the product code
Hub Bontrager 1248
The old one was not good without all the three shims, but could be if one would be just a little thinner.
I had mine replaced under warranty as well, seems like it’s a common fault with that hub!
I think that the freehub play could we fixed if one of the shims would be just a little thinner.
I'll try to keep this wheelset alive couple of months and replace them with DT Swiss 350 + EX511 set. The OEM wheels will be good for commuting with slicks and when selling the bike.
    672K
