Levo Gen 2 Why's oil coming out by the motor case?
righton
20
2020 Turbo Levo. Is there oil inside this area? Or this oil came from elsewhere? There's no oil drip in the frame or shock area. The oil is just in this casing seeping out. (Photos attached)
urastus
⚡The Whippet⚡
May 4, 2020
1,548
994
Tasmania
Well, it's not meant to come out, if it has come out. If you're sure it's come out, and not from another source - I'd have it looked at under warranty. The oil will need to be replaced at the least. I have a history with motorcycles, admittedly more speed involved. It was often hard to discern where a leak came from - much easier if it is a static object.
salko
1,241
838
SLO
Im pretty sure there is no oil inside the motor, belt drives are not lubricated with oil...
Levo-Lon
175
200
Uk
Well it's definitely not from your chain !!
As said check the seat post , shock ?maybe but you would have lost all the damping by now ..so the rear would be bouncing like a pogo stick
righton
20
not the shock, i just checked frame and shock area if there's any drip. but could be the seat post, i'll check and report back.
526K
