I’ll start the ball rolling, this week she’s had. New kmc chain, cassette, renthal ring. Also mech and dropper cables. New front and rear pads. A new bar remote(warranty). Fork service.
Hoping for a couple of spend free weeks now. Big mileage costs!
A bunch of electrons!
What was the cause of the stiction, or more importantly what was the cure?
mine was in for warranty at 250kms aprox.
awfull
this is as the cure.
I bought a Garmin edge explore, silicone case, stem mount from superstar and a tempered glass screen protector from Germany, all before I knew about the Garmingate saga, just my luck ?if it’s not sorted soon I’ll be sending them all back, nearly forgot, a Bosch purion cover for those super wet riding days
A new pink bell.
But concerned it is already the obsolete 2020 model.
There is an "all new" 2021 v2.0 version available, with improved spring rate, damping response and new high grip, tri-compound rubber on the thumb button. A couple of grams lighter and a new on-trend colour way for 2021, now dusky pink matte.
Oh, Damn... Load the money cannon again :(
Not to worry, I'm sure they'll acknowledge the much publicised issue of the weak spring that snaps when you overheat it by using it too much and bump your warranty up to 4 years any day now.
Got the 108 Bontrager upgrade kit in the post today. Fitted tonight and must admit I was sceptical when I ordered but it does make a difference. It picks up instantly. Well worth the £15 for pawls and springs.
Got a part number for that?
A new pink bell.
You might just be able to update its firmware; you might get some new ringtones!
And it continues. Upgraditus is setting in. Just ordered some Marzocchi Z2‘s to replace the Suntour things that came as standard. I hope they're as good as the old Z1’s I used to have on my old 5 Spot. I have very fond memories of those making splishy sploshy noises while being as plush as a plush thing over rocky bits
Kenevo had a new zeb select fork and the voltage had a zee mech and shifter ?
4 of these for our 2 bikes. Very pleased. They fit a 29 inch 2.6 Fully inflated tyre.
we travel with both bikes in the boot of the car so these are ideal.
    670K
