Official Merida eOne-Sixty thread
Thanks I just looked on their website I couldnt find them might have to make a call
Yes they're so busy they need another staff member to update the online store. Just phone for any item you
Yes give them a call as they are so busy they need a new staff member to update the online store. Ask for the owner Angus and he will have it in stock or try to get it.
Some specs of the new 2021 model 9k and 10 k
9k Aus is $11000
10k Aus is $13999
2021 Merida e160 9000
01. FRAMEeONE-FS CFA II; MAT carbon; 150 STR; 29/27.5" WHS; 148x12 AST; intube;
02. SIZESM-L-XL
03. FORKFOX 38 Elite eMTB+ Air; 160 STR; Tapered; 51mm fork offset
04. REAR SHOCKFOX Float DPX2 Elite; platform
05. DRIVE UNITShimano STePS
06. BATTERYShimano STePS
07. BATTERY CHARGERShimano EC-E8004; 4A
08. DISPLAYShimano STePS
09. SWITCHShimano STePS
10. REAR DERAILLEURShimano XT RDM8100 Shadow+ 12
11. SHIFTERSShimano XT M8100 12
12. BRAKE-FRONTShimano XT; 4 piston
13. BRAKE-REARShimano XT; 4 piston
14. ROTOR-FRONTShimano RT-MT900; 203 mm
15. ROTOR-REARShimano RT-EM910; 203 mm
16. CHAINRINGShimano CRE80-12-B; 34 Tooth
17. CRANKShimano FCEM900; 165 mm all sizes; hollow
18. CHAINCNM8100
19. CASSETTEShimano M8100; 10-51 ATC; 12 speed
20. PEDALSVP; VPE-527
21. HANDLEBARMERIDA Expert eTR; 780 Wide; 20 Rise
22. HANDLEBAR STEMMERIDA EXPERT eTRII; MAT aluminium; 35 DSH; 0 ASD
23. STEM LENGTH40 mm all sizes
24. SEAT POSTMERIDA EXPERT TR; 30.9 DSP; 0 SSB; XS 125 SPT - S/M 150 SPT - L/XL 170 SPT
25. SADDLEMERIDA Expert CC; V-mount
26. HUB-FRONTDT Swiss
27. HUB-REARDT Swiss
28. AXLE-REARMERIDA EXPERT TR; including removeable lever, 6/4mm allen key
29. RIMSDT Swiss Spline HX1501 ONE 30 boost; 110x15 WHF; 148x12 WHR; 30 IWR; Centerlock; microspline; MAT aluminium; Tubeless ready (tubeless tape and valves included)
30. TYRE-FRONTMaxxis Assegai; 29x2.5 "; fold; 3C MaxxGrip DD
31. TYRE-REARMINION DHR II DD; 27.5x2.6 "; wire bead; 3C DD
32. MUDGUARDC093-02F + C093-02R
33. LIGHT FRONTE-BIKE POWER STVZO E115, reverse MERIDA Custom Mount
34. LIGHT REARLED FEMTO USB REAR STVZO
35. OTHERMERIDA Multitool with saddlebox
Merida e160 10K
02. SIZESM-L-XL
03. FORKFOX 38 Factory eMTB+; Air; 160 STR; Tapered; 51mm fork offset
04. REAR SHOCKFOX Factory Float X2; platform
10. REAR DERAILLEURShimano XTR Shadow+
11. SHIFTERSShimano XTR M9100
12. BRAKE-FRONTShimano XTR; 4 piston
13. BRAKE-REARShimano XTR; 4 piston
18. CHAINCNM9100
19. CASSETTEShimano M9100; 10-51 ATC; 12 speed
24. SEAT POSTSP REVERB AXS; 30.9 DSP; 0 SSB; XS 125 SPT - S/M 150 SPT - L/XL 170 SPT
29. RIMSDT Swiss Spline HXC1250 spline 30 boost; 110x15 WHF; 148x12 WHR; 30 IWR; Centerlock; microspline; MAT carbon; Tubeless ready (tubeless tape and valves included)
At 14k the Merida will be a tough sell, the XT drivetrain is probably better for an Ebike than XTR.
I have the current E160 10k and its a good bike but i did not pay anywhere near retail at retail i would have passed.
Does anyone know the cable lengths for Di2 conversion? 1000mm for derailleur and 600mm for shifter?
Cracked my 900e frame at the top tube/seat tube junction. Apparently a common place for them to let go.
We will see how good/painless Merida Australia warranty is I suppose. I'll keep you updated.
Is yours a large? Seems to be common, I'm keeping a close eye on mine
yep, I don't foresee many issues as this is a wide spread issue. More the time I'll be off the bike. I ride 3-4 times a week and this is going to kill me mentally.
Just my luck to crack one during a worldwide pandemic lol.
Lucky boy.... I'm out most Saturday mornings but that's about it for me. The joys of working full-time and having a family haha. Would be nice to live closer to a trail centre, i could ride before or after work... It's a strong consideration to where i will buy a house next year ?
I have a merida e140 LTD (aluminium) 2020 model. It isn't a year old and has about 1500km. I just discovered the bottom shock mount has some play. Would you consider this a warranty issue? The bike hasn't had hard use judging by my low suspension pressures and tyre pressures and I rarely bottom out with those low pressures.
I certainly would take it back and get it warrantied.
Thanks horspwr. I wrongfully jumped to a conclusion. I don't normally have things come loose on me - it was loose! Bit of a concern. I had it apart about 3 months ago to remove the tokens - cleaned, greased and torqued. At this point, I think I'll clean the threads of grease and use some contact cement as a thread locker. I can imagine how it happens with that pivot point - much up and down and some rotational force.
Just been told by my Adelaide LBS that the 2021 e160 500 model that I had a deposit on will not be proceeding as an available model
Not sure if this is Aus only or world wide
Options are to go to the cheaper 300 or more expensive 700
Lower specs on the 300 aren't desirable so trying to get Merida Aus (Advance Traders) to reduce the price on the 700
Still saying December delivery though
Decisions, decisions !
How does it compare to the LTD (aluminium) model? Aluminium model is cheaper and easier to live with. Personally, if I was you and you still have your clockwork bike, I'd chill. It's all their way right now; it won't be long till that changes.
The LTD version was the 2020 model
The 2021 300 / 500 / 700 are all aluminium - I agree with you regarding this
Been procrastinating too long over buying an eMTB already
Now I've pulled the trigger I will follow through
Just hard to stomach having to fork out over an extra $1k through something I have no control over
What sort of discounts are peeps getting in Au? Looking at the E160 9000 (2021)
We bought a 9000 and an 8000 and I told them to take a grand off each and I was happy. Called my local shop and told them I would pay a deposit now over the phone if they could do that and after a minute of being on hold they said OK let's do it.
    Join 43,188
