Grinding when pedalling backwards
There is no Brose kit to solve this problem, the Brose motor belt kit has a replacement seal that can be used for the right hand crankshaft bearing, but it doesn't help with the water that comes through the left hand crankshaft bearing and crankshaft needle roller bearing.
But, it's here if you want to see it. ROTWILD BROSE BMZ Zahnriemen Ersatz-Kit Velo-Direct.ch
So your advise for me with my brand new motor would be to inject silicone grease into the little void on the right side of the crank to help protect the bearing face? Can this be done both sides or is there only a void on the right side {drive side}?
No, if you have a brand new motor, it will be fitted with the new seal anyway. If you are expecting to do a lot of very wet riding and bike cleaning, then you may want to remove the chain ring spider and inject some motorex 2000 bike grease down in between the crank shaft and the sprocket drive. And yes, smear some of this grease over the left hand bearing from time to time.
If you are just road riding, I wouldn't bother. Just enjoy your bike. (y)
I do like a clean bike so I’ll put some grease in the dreaded void. Thanks
Here is an extract from 2019 Levo workshop manual. It sounds like the design hasn't changed so this would also apply to earlier year models.
Just finished a Brose overhaul video if it helps you guys?
That’s quite a job for the average Joe.
If we do not have the skills or tools to do the job and are not near you. Who would you recommend to do such a job ?
Somewhere that rebuilds car transmissions?
A quick update, just had the new motor installed and was wondering what version of software everyone considered the best. The new motor was from nov 2018 my old one was from Mid 2017 there are several casting differences and the new motor has three holes filled in where on the old motor they were covered by a white sticker. The software on the new motor is 5.04 I’m trying to remember if I liked that version or not. Any feedback greatly accepted before I upgrade to the latest.
5.04 is the latest
I gained 200w of peak power when I went from 5.0 to 5.04
He is right; Brose original FW - limited to a 15A max current instead of the 20A bespoke FW that Specialized use. See official word from Specialized here
My bike is only putting out 15 amps after the new motor installed. Shop didn’t have any luck forcing update so a specialized rep is meeting me at the shop tomorrow. Specialized all the way with customer support just awesome.
That surely sounds like the big needle bearing gone south and like other have said, if you still have warranty get it in. If no warranty you can try to to put your bike down on the non drive side and let some thin oil seep down. However if the oil get past the bearing it can destroy other internals. Anyway if no warranty the motor will eventually die no matter what.
Karsten
Hi karsten this exact same noise as started on my 2020 levo today, was it the bearings and what was the solution to fix it please
Thanks brett
Thanks brett
Question? Do you two clean your chains on the bike ?
I lost a motor chain side bearing from what I could see the bearing had rusted from excess degreaser collecting behind the drive side front sprocket. I used the chain turbo cleaner on the bike. I now remove the chain to clean it and so far the second motor has been good. When the noise happened it was noisy when I pedalled backwards.
I clean the bike and chain with rino gue and wipe the chain with a rag
    Join 43,188
