Levo Gen 2 Aluminum Chainring options for Turbo Levo 2019
motoadve
Washington
I see Blackspire makes it but which model is the one for the Levo? What BCD?
Any other options out there in aluminum?
I'm using a Praxis Works 30T alloy chainring. 104BCD. The chainring mounting holes are threaded like the Steel OEM version, so it mounts with very little fuss. I'll take pics later and post up.
Thanks, is it this one?
Yes. That's the one I have.
Thanks does it comes with the bolts?
How do you like the 30t on the Levo, thinking of putting a 30t , lots of long uphills where I ride.
The bolts are the same ones that hold your current 32T chainring on. And yeah I’m really happy with the 30T. Lots of long, steep climbs where I live as well, and the 30T helps me keep a higher cadence with low/med power levels while I’m climbing.
Praxis Works Ring making anoying noise when a litle bit dirt on it:mad: Now i have a simple Zee 38 Ring and it works fine.
    670K
