Bottle cage
Jasext
Swansea Valley
Anyone manage to find a bottle cage with side entry or similar that doesn't cost a fortune ? Due to the frame i cant fit a bottle into a standard cage on the 160 or 140 i have.
Not sure about side loading but mine fits a 500ml bottle just fine and doesn’t snag the frame getting the bottle in or out of the cage due to the flexible material of the cage.
Bike is the 2020 160 model - cage was about £8 online (can’t remember what website)
granted its a smaller bottle and only ideal for smaller rides but anything bigger, I just wear the camelbak ?
I’ve always used specialized swat side mount bottle cage, can also fit one up components pump on there discreetly.
Both have never fallen out?
Hi,
Lezyne Flow side load, I have the cheap version which is under a tenner but they also do a carbon version.
Hope this helps
well when i first got my cube 2020 bike in 10th of dec 2019 i bought cube one grey to match bike , then was thinking of second one so bought an other one and bought twin bracket so can hole 2 water bottle and as its just we bit over it easy to pop out so thats what i did am happy
I’ve got the same bottle holder ?didn’t know they did such a bracket - any link to it?
do your legs rub the bottles at all?
the adapter is not cube , i bought from ebay there few different ones out ther other than 1 i bought as for legs well depends i think on way you ride ,it might rub if have legs real close to your frame ,between edge of frame and cadge for my cube is about 1 inch and half ish ....if get some paper at about 6 and half inched ,bend it to fined middle then and the middle of ur bike frame then flatten it thats how much both cadges are when on and over lap ........i taken picture of under it so frame to edge of cadge as said is about 1 and half inches .. ... Aluminum Alloy Double Headed Bicycle Bottle Cage Extender Mountain Bike E5A1 | eBay
What size of the fidlock bottle did you manage to fit to Cube Stereo?
I currently use the BOA system with a small bottle filled with toolls, tube etc. (From Topeak) BUT the BOAis much higher than the standard bottle cage so you can't really use it for a drink bottle.
I think if I remember rightly that the large bottle didn't fit. I can't look at the moment as I am in Switzerland
Water bottle cage from Blackburn is my best choice. I did a test run with two attached to the forks of my bike pack rig; On one side I have a stove to boil and fuel, on the other I have 32 oz of water in a Nalgene. both fit well, and with the included straps, there's no concern about items slipping or coming loose. The back of the straps are rubberized for a non-slip grip, but they don't stretch, so keep them well and tight.
