Earlier this year I tried several different ready to go wax lubricants having hot waxed chains for 12-18 month's. I did so because of the faff of the waxing process. I’ve since returned to hot wax (paraffin mixed with Vaseline oil) as despite the faff, I found it less time consuming overall. Only getting 1, maybe 2 rides at best, with ready to go preperations.
I get around 100+ miles between changes with hot wax, so 3-5 rides. So although I leave the chain in the cleaner for 30 mins, dry, then hot wax for 30 mins (normally 3-4chains at a time; mine, wife’s, sons etc.) I’m spend less time swiping chains over and cleaning them.
I think, can’t quantify, the ready to go prep‘s also worked out more expensive. It cost me about £60 to set up with wax including, wax, oil, cooker & ultrasonic cleaner. Been using that for 12-18 months and will probably last another 10 at least. I spent nearly that on 4 different lubs in 6 months, bearing in mined I’m maintaining 3-4 chains.
I’m not saying this is better than other options, do whatever works for you, just trying to provide some insight.
p.s. If anyone can recommend a ready to go prep that will last 100+ miles, can be used in wet & dry conditions, wont be wash off by rain, mud etc. I’ll happily give it a try.
