Does this work on the Bosch motor?Bought something like this recently. Think it’s a park tool version. Has a blue handle. Does the job perfectly.
Just bought some new smaller crank arms on my rail 5 2020 what crank removal tool is needed and what’s people’s past experiences..
Many thanks
Beware: that looks like a Park Tool CCP-22 which is NOT suitable for Bosch Gen 4 motors. That end bit is too small and disappears into the hollow axle without giving any purchase for the puller to work with.
Yeah mine was a Bosch Gen 2
I'm pretty sure that the 2020 Trek Rail 5 has a Gen 4 motor.
CrikeyThe one I got was part of a bundle of tools to remove the front sprocket on a Bosch Gen 2 motor (2019 Cube)
if you go to e-bike shop.co.uk you can get them there.
You will need a different too however if you have Active Line / Active Line PLUS Bosch motor as this has a smaller spline.
the website is very informative in this regard
www.performancelinebearings.com
Crikey
>£45 for delivery
Ouch
Going for this option instead
Homepage - eBike Motor Centre (Performance Line Bearings)
Tried that lock-ring tool... Don't bother with it.
The teeth aren't very deep so they'll jump out because of how wide the engagement is and just strip the holes.
Here's the solution you need... String
Or light rope ... I happen to have a lot of kite line lying around.
Tie a bent bar or spanner to the lock-ring
Lash it down tight avoiding the crank in the center.
works easy and you don't need to spend anything.
Even better... I serviced the gearbox by cleaning up the grease and circuit.
Cleaning the gears and re-greasing.
Easy
Error codes vanished.
rides fine again (Admittedly still got a little resistance and noise ... give it a few months)
