Adding Di2 after EW-EN100 upgrade
stona1
20
9
Gdynia, PL
Hi,
I already removed E8000 display in my bike to have clean cockpit. Now I am using Garmin EDGE 530 with EW-EN100 only. My bike have mechanical XT rear derailleur (1x11). I am going to switch it to Di2. Problem is that after removing original display E8000 I do not have any empty ports to connect electronic right shift switch (SW-M8050-R).
Can I use Junction B Internal Wire Routing 4-Port SM-JC41 (SM-JC41) to multiply ports?
Best regards
Arek
I believe there is someone on the forum who has done this, but I am struggling to find the thread.
RickBullotta
1,777
1,520
Hi,
Best regards
Arek
Yes.
Have you removed the mode controlle/handlebar swtich as well? If so I wonder if you could just plug the shifter into the other port on the EN module?
B1rdie
836
1,034
Brazil
Thats what I intend to do! Just bought the ewen100 on ebay!
It seems that there is one port for the controller on one side and a port for the dy2 shifter on the other side.
yup, here's my set up, I run the mode controller on the right though.
525K
