EebStrider
The mounting of the Kiox on my 140 Race seems to be in a very vulnerable position. Has anyone relocated it via a stem mount, if so how did you do it?
This should help.
Bosch Kiox Display Holder Socket | Bosch System Shop
My understanding is that you just swap the base plate from one holder to another.Thanks. I saw that one yesterday, while browsing, but didn’t know if it was the right part for the job. I assumed it would be more complicated, as surely Cube would use those, if it was that straightforward?
I'm sure the existing stem bolt would be long enough to do the job.Will I need any additional bolts etc, or will the standard stem bolt work with that?
I've flipped my mount over so that the display sits in front of the stem. Doesn't get knocked anymore by my knees, or when I lean over the bars to open gates and things.
Can be done by undoing the hinge bolt that the mount attaches to the arm and fitting the mount the other way round to the arm. ( Obvious what you need to do when you try and flip it. )
Setup can be seen below in the picture:
Hi mate where did you order this from I’ve been looking for ages and can’t find one anywhere!I have ordered the top tube mount now from Trek shop. £13.00 posted. Top tube placement should be the best position in my opinion.
Please note, I believe that some of the rails don't have the little screw on the top tube to mount it. Make sure you have it before you order it.
Is that the top tube mount that’s fitted on the rail 9.9, if so which particulat shop did you get it from, I can’t find one anywhere!
Yea thats the one I asked for fellaIs that the top tube mount that’s fitted on the rail 9.9
I'm not convinced the stem is the best place for 200 quids worth of glass fronted electronics and I have a very sorry looking Intuvia head unit that would agree...
Yes, the gaffer tape is structural, thanks to an OTB at Cannock.![]()
Think the OTB was a clue![]()
You're not wrong. Perhaps once all this is over we can meet up and you can show me how it's done?
I'm not sure I have the skillset required for the Surrey Alps though...![]()
