2019 Levo Frame Bearing Kit
GEE ARR
MIDLANDS
Hi everyone...I've been looking everywhere on t'internet for somewhere that sells a complete set of frame bearings for a 2019 Levo. Has any of you managed to purchase a full kit from anywhere? Failing that does anyone have a list of the sizes so I can search online for them? I've searched the forum but i can't find anything. Thanks for your help!!
I wanted good quality bearings for my 2019. I bought individual Enduro Max. 10 pieces of 6801 and 2 pieces of 6901. I used the RRP bearing extraction and press tool. It works great. For the main pivots (6901) and the inside Horst link bearings I used the bearingprotools extractor. Easy.
Thanks Ted...I've always replaced with Enduro Max...Have you got the exact bearings you ordered?
Yes. The 6901 are for the main pivot. The 6801 are for the Horst links and other rear pivots. Here is a Specialized document that shows the bearings.
Hi
I need to replace a few bearings on my pivot on the Levo comp 2020
How easy and what tools are required to replace the bearings please ?
I need aluminium spacers for the rear pivot. Only find bearing set S180600003 which not included spacers
I bought all the bearings and the RRP tool. Do I need to drop the motor to get the main pivot bearings out or is it possble to remove the dust shield to gain access. What are the torque specs for all the pivots and shock bolts? Thanks!
I did not drop the motor or remove the swingarm. Access was pretty easy. Torque specs are in the Levo manual.
