Rattling internal cables
Brooky
Anyone know how to cure rattling internal cables on a Kenevo?
Rob
I used this on my Yeti build........... Works really well. Just be patient installing it! It is also a little spendy, but comes with enough to do several bikes.
Internal Housing Damper | Jagwire
I had that on my cube up in the head area.
I pulled the battery holder out and inserted a bit of foam pipe insulation up there around the cables. Actually it was the packaging material they used when the bike was delivered, so a bit thinner than the normal Pipe insulation. Made a HUGE difference.
My Cube is also rattling very badly. How easy was it to remove the battery holder? Thanks.
To tell you the truth, it was a royal faffing pain in the bum!!
I can't even help you with it as I am not sure I did it right. Also my battery is more difficult to get in or out since I did it. :-(
There are 2 rubber stoppers that have to be removed with screws under them. Plus the 2 bolts at the top and 2 at the bottom. BUT there are multiple washers etc under each bolt that have a tendancy to fall out and dissapear somewhere into your bike frame.
And I had to remove the lock as well.
Pop to builders merchants and get a can of expanding foam.
Pump contents into all hollow voids of your bike.
Stand back and watch your beautiful bike become worthless but rattle free ?
Or simply remove slack in cables and use a bit of foam zip ties ect
Sounds like my exact problem. Is this the TCU cables rattling?
mine was the dropper cable as it passes the TCU and down the top tube ,carbon frame always picks up more noise . Slipped a length of insulation foam in.
