Kenevo 2020 mission control settings
Brooky
11
Ive got a Kenevo Comp 2020, it’s probably been asked before but can’t find it but I’m after some setting suggestions for the infinite tune please, don’t want to spunk the battery too quick
thanks
Rob
Martinintirol
63
259
Zillertal, Tirol, Austria
thanks
Rob
I guess mostly it depends on the terrain you riding. Just got my first emtb Turbo Levo 700wh.
I live in the Alps and on my 6th ride today.
I did 24km, 2.5hrs, 800hm all in 35/35 setting. The first 12km are straight up, but I just use the gears, mostly bottom three sprockets to keep a good tempo and not drain the battery. After this I had 50% life left. Coming down you aren't really using any battery from what I can see...
Too much snow to use the Turbo mode but I shall be experimenting with Trail mode next. Currently at 50/80. In all honestly the motor torque is so good the eco is pretty perfect unless you are racing uphill imo.
thewildblue
136
110
Bucks
Turn off shuttle, this eats the battery. I Generally run 30/35 60/80 and 100/100, accel 100 and shuttle 0. If its a short "power ride" I will turn shuttle up and do a battery drainer.
Mcharza
E*POWAH BOSS
Aug 10, 2018
2,520
4,829
Helsinki, Finland
I had to change the settings compared to 2019 Kenovo because I think 2020 Kenovo will assist more.
My settings:
18/40
38/60
78/100
Mission Control allows only with even numbers 5,10,15 etc., so I used the BLevo App
525K
