Replacement Coil (heavier than 650lb) for rockshox deluxe ultimate coil
Gary
Old Tartan Bollocks
10,496
10,690
the internet
Have you ruled out a blown shock? or lost charge internally (pretty common failures for heavy agressivew riders)
To check:
remove your shock and remove it's spring then refit it to your bike with no spring.
Then cycle the rear through it's travel a couple of times noting compression resistance/rebound speed. Next open all damping adjusters (full fast) then one at a time close (turn to slow) each compression/rebound adjuster and feel the resistance. there should still be both compression and rebound resistance even full open and should increase a lot as you slow down each adjuster.
Basically mimicking what you'd do to test a shock on a dyno
Gary
Old Tartan Bollocks
10,496
10,690
the internet
Killswitch73
371
230
West Midlands
To check:
I must of read your mind as i did that today with all this spare time lol
anyway the shock is bang on fine .
but ...i think im panicking for no reason as i did my sag again today with no kit just shorts, trainers and top on . and my sag is 30/31% .
with a bladder and helmet on im thinking this will be around 33-35% sag .. or am i wrong ?
if losing a few lbs over the next month this will perhaps make the sag around 30% with kit on ...Maybe !!
but im actually shocked (no pun intended) that my sag was only 30/31% .
Gary
Old Tartan Bollocks
10,496
10,690
the internet
perfectly acceptible for a DH set up. you might need to run some highspeed damping.
and might need to get used to pedalling a lower BB. - The Emtb rider's crutch ;)
Just remember. low BBs corner better. so stop pedalling into shit and rail the turns
Joeyrotundo
42
42
Canada , Vancouver Island
Fox is the only one I know of that has some heavier springs. I have a 700 that I’m not using since I went back to air on my ‘16. Not sure how the diameter compares between Fox and Roxkshox.
Internal Diameter of MTB Springs
35mm = Fox
36mm = CCDB, Bos, Ohlins
38mm = Rockshox
There are some others too , unfortunately.
Ride
Smile
Recharge
Repeat
Joe
Killswitch73
371
230
West Midlands
Bottom bracket is higher anyway with it set to high in flip chip and with 160mm lyriks not the 150 standard . Bike is 160/150 not the 150/140 .
Gary
Old Tartan Bollocks
10,496
10,690
the internet
Yeah. pretty much every Emtb has a fairly high (IMO) BB
your 10mm longer lyrik only raises the BB by about 3mm tho.
Killswitch73
371
230
West Midlands
Mind is made up and will order a Levo SL once this virus has done one .. you only live once and I’m going to enjoy life to the full . My missis also wants one . Told her she needs to sell her stumpy that I built for her as well and I will loan her the rest towards it . Lol she like that purple one as she’s got purple stuff on her stumpy .
Milas27
Iraly
What is your weight?
