Folk use BING
Folk use BING![]()
Have you ruled out a blown shock? or lost charge internally (pretty common failures for heavy agressivew riders)
To check:
remove your shock and remove it's spring then refit it to your bike with no spring.
Then cycle the rear through it's travel a couple of times noting compression resistance/rebound speed. Next open all damping adjusters (full fast) then one at a time close (turn to slow) each compression/rebound adjuster and feel the resistance. there should still be both compression and rebound resistance even full open and should increase a lot as you slow down each adjuster.
Basically mimicking what you'd do to test a shock on a dyno
with a bladder and helmet on im thinking this will be around 33-35% sag .. or am i wrong ?
Fox is the only one I know of that has some heavier springs. I have a 700 that I’m not using since I went back to air on my ‘16. Not sure how the diameter compares between Fox and Roxkshox.
How many turns of preload have you got on the spring?
Good advice Gary BTW![]()
The correct amount which is 2 full turns .. no amount of preload is going to make any difference . .This, how much preload?
Anything more than 2 turns and you have too light a spring rateHow many turns of preload have you got on the spring?
Bottom bracket is higher anyway with it set to high in flip chip and with 160mm lyriks not the 150 standard . Bike is 160/150 not the 150/140 .perfectly acceptible for a DH set up. you might need to run some highspeed damping.
and might need to get used to pedalling a lower BB. - The Emtb rider's crutch
Just remember. low BBs corner better. so stop pedalling into shit and rail the turns
I must of read your mind as i did that today with all this spare time lol
anyway the shock is bang on fine .
but ...i think im panicking for no reason as i did my sag again today with no kit just shorts, trainers and top on . and my sag is 30/31% .
if losing a few lbs over the next month this will perhaps make the sag around 30% with kit on ...Maybe !!
but im actually shocked (no pun intended) that my sag was only 30/31% .
