Question about Turbo Levo Remote
Bluishblue
7
Italy - Rome
Does anyone know if is possible make a DIY remote walk switch on a Turbo Levo 2017-2018?
Is this a simple 4 button switch or is it a canbus controller?
The remote switch has 4 wire on the connector, can I check it with a multimeter?
Thank you
Bluishblue
7
Italy - Rome
Thank you so much, I've read it, my question is: is possible use a simple handlebar button? I need it only for walk assist.
Like this one.
Bluishblue
7
Italy - Rome
You have 4 switches in the remote control, so you can use buttons like the one you show.
Thierry
Thank you Thierry, do you know which pins are the right one?
I removed crank, cover and pick up the small cap and i found 6 pins on the connector.
I'll appreciate if someone have a Brose pinout schema.
Francesco
ThierryGTLTS
119
55
Belgium
Francesco
For those with TCU, round connector, Pin 6 is the common, but I don't remember for the others.
Thierry
525K
