Earlier in this thread JonnyNoKnees posted 6 mm x 20 mm with the Fox part number:
Fox 5-Piece Aluminum Mounting Hardware Kit IGUS Bushing Shocks 6mm x 0.787" 20mm
MPN:
803-03-237
I ended up measuring the hardware mounted in my stock shock.
I only found the Fox 6 mm x 20.83 mm version locally...it was too tight for me to easily install the new shock.
I didn’t think the extra .83 mm would make a difference...but it did.
I ended up using the 6 mm x 20 mm hardware from my stock RockShox Deluxe select + shock in the new Cane Creek (I couldn’t find any Cane Creek hardware in that size to buy online/locally).
I also had to get a local shop to push out the bushing in the eye that the flip chip goes in (otherwise the flip chip wouldn’t fit)...I think I had this done on both a Manitou McLeod and the CC Coil IL.
I used 6 x 20 mm RockShox hardware in both.
I hope this helps someone else.
note: this was on my 2020 Levo Comp...I usually have a LBS do most of the work on my bikes, so I’m not a competent wrench.
