Gen 4 wheel size
Couchy
Nottingham
Picking up a gen4 Bosch orbea. Comes with 29” wheels and I want to fit my 27.5 hopes to it. ive read if I upgrade to the kiox display I can set my wheel size, is this correct or do I need to get the dealer to do it ?
as far as i'm aware the wheel diameter is hard coded into the motor by bosch, dealer software cant change it outside of the preset range that is available on the display settings.
I’ll answer this in case anyone is interested, pocked new bike up and dealer altered the wheel circumference from standard 29“ to 27.5” so I can swap my wheels. Yup they only have fixed figures to play with so no dropping it anymore to get extra speed !
I adjusted mine on my Kiox they other day. In settings is an option for wheel size, however you can only adjust the wheel size 5% up or down. After accurately measuring the diameter of my wheel by measuring the distance travelled after 5 rotations, I set the value in my Kiox. I then measured my speed using GPS and it was showing 22kph on the bike and 20 on the GPS. I eventually adjusted the diameter to the limit of the range and got the speed to 1 kph difference, but still showing too fast.
I'm guessing mine is over-reading too; The trip meter said 17 miles and Strava said 16 today.
Hy,
did you correct it to the lower limit.( smaller wheelsize )?
Yes, to the limit and yes smaller.
My bike shop did the same.
Speed should be correct and distance to.
Top speed no difference.
I think speed is limited from the amount of puls from the speed sensor.
The wheelsize only a correction of the speedometer.
I had hoped a little bit more speed.
The speedo will read the same, but it will be closer to actual speed so you should be going faster.
