Levo SL Gen 1 SL Levo Shimano build
ridesantacruz
Santa Cruz
I thought I would share my Levo SL shimano build. I don't care for Sram components except the AXS seat post so I decided to buy the SL carbon comp and then do a full custom build on the bike. I installed 11speed instead of 12. I feel on the ebike it's unnecessary and not a good fit. 12 speed is not robust enough and to finicky. I finished the bike today and took her for a maiden voyage. 3 hrs, 30 miles, 2500' of elev gain, 33% of battery life left, and lots of smiles. The ride included the range extender and I rode 90% of the ride in "trail mode". I will upgrade the cranks to carbon when they are available. I would like to upgrade the shock to the DPX2 or X2. I am hoping someone will do it and post it.
This was my parts list:
Pedals XTR M9100 PD-M9120
Brakes XTR M9100 BL-M9120
Shifter XTR SL-M9000 11-speed
Derailleur XT long cage SGS Shimano XT RD-M8000
Cassette XT CS-M8000 11spd (11-42)
Chain CN-HG701-11spd
Sram AXS Seatpost
Bars ENVE M7
Stem Industry 9 35mm
Fox Fork 36 grip2 150mm
Fox DPX2 210x52.5mm
Reserve Rims 30 with Industry 9 hubs
Centerlock 203mm IceTech Rotors front and rear
Maxxis Minion DHF 2.5 – front
Maxxis Minion DHR II 2.4 - rear
Cushcore
Odi Elite Pro Grips
Nice build.
I must admit after short test ride of the Comp Carbon SL on Sunday the SRAM kit (and other finishing parts) felt cheap compared to my current Shimano/Hope equipped bike. Until Specialized sell a frame/motor then the CC is the best option to build the bike it should be.
I can’t see the weight being much less than 18kg but then it’s not always about weenying but function and feel.
Nice build, there should be at least one SL model from Spesh that comes set up similarly to this.
Are tires standard EXO case?
I am curious about the weight myself, including the attached range extender just to see how it stacks up against full power models.
The build was not about weight, it was about feel and function. The tires are EXO+. The heaviest weight is the stock Carbon comp, other two photos are post build with and without the range extender. See weights below:
On the X2 - Marshall Mullen is running on at 210x55mm fox ID: DX6S Says it works great with that tune.
I have an X2 210x55mm sitting in a box waiting to be installed. Not sure if it's going to be an issue with the range extender. When I have some time I will install it. I was hoping to see some pictures of one installed before I start.
He claimed that it fits fine. Curious to see your results. IF you don't mind, post up your fox id as well.
Edit: not sure what size he was riding. I am XL, so assuming an X2 will fit that
Nice build. How does the front end feel with the factory 36? Did you consider going to a 160 mm or do you think sticking with 150 mm is a better option? What offset is it?
I'm thinking of doing a fox 36 160mm fork and a 210 x 55 rear shock also. I find the SL with the 150mm fork almost too responsive in handling and want to add some stability by slightly increasing trail.
Same - 160mm, maybe 44mm offset (longer trail, more neutral). Also (still) waiting on an offset bushing to try out. The quick handling is awesome, but i would give up a bit of the twitchiness to have some more neutral feel
I agree jcmonty as I'm coming from an enduro type of geometry bike to the SL and want just a tad more stability and grip (front and rear) from the fork and shock upgrade I am planning.
The fox 36 feels great, I run a little less air then recommend by Fox, bike feels plush but stable. The fork came off a Specialized enduro and is the same specs as the Levo SL, 150mm travel with 51mm offset. I think the 150mm travel is just fine for this bike. The 160mm might be an issue climbing steep hills, the front end already feels like it wants to come up on steep climbs.
The X2 shock does not work with the range extender on medium SL. The reservoir interferes with the the external battery. It might be possible to carve out part of the battery case to make it work but more hassle then it's worth. I will be returning the X2 and getting the DPX2 instead.
I wonder if you mounted the bottle cage to something like the Wolftooth B-RAD mounting base, if it would allow you to drop the cage enough to get you the clearance you need.
Dropping the water bottle cage will cause another issue. The cord is surprisingly stiff and if you don't have the water bottle cage at the correct height, it makes plugging and unplugging the cord difficult.
160 front should be a minimum from what I felt when riding it. I’d go 170 regardless of feel, but I’m a gravity whore. Please make a evo version or even better an enduro SL. ?
I may have missed it scanning the thread, but what size are you on? Medium?
My bike is a medium. Might work on larger bikes.
how tall are you for this bike ?
I have a medium Kenevo 19 and a large stumpjumper 19 .. the stumpy is a perfect fit for me .. really am thinking of ditching both bikes and getting the comp carbon SL and putting my lyrik 160 ultimates and full AXS set on the bike from my custom built stumpy .. and my carbin Nextie wheels .
Love a Shimano build, really tidy bike.
My bike mechanic says "how do you spell SRAM... s...h....1....t.
the main reason I don't want to buy a levo is the sram builds
i know right, not that i need another bike but i couldn't resist full shimano
I am 5'8", I feel the cockpit is a little short on the bike. Fortunately, I like it like that but I think a lot people would prefer to be more stretched out over the bike.
A good plan. My Kenovo 19 was Medium. New Kenovo 20 is S3 and my Spesh Evo is S2, both bikes feels the same.
After installing the DPX2 and trying to get the sag correct for my weight, I was having to put in a lot more PSI than I thought I should need. I weigh 180lbs with riding gear and usually start at about 180PSI for setting the sag on the Float shock. To get the sag correct, on the DPX2 I needed about 240PSI which seems too high. The original float shock from Specialized had a 0.8 inch volume spacer in it. I was going to swap the volume spacer to the DPX2 which did not have any in the shock but the shock shaft is larger. So I ordered a volume spacer kit for the DPX2. Unfortunately, the DPX2 shock spacers are not the same sizes as the Float shock spacers. I am planning on using the .86 inch spacer to start with because it's the closet size to the stock spacer. Anyone else come across the same issue? Please share which volume spacer you put in your shock for the SL.
Did you equalize the positive and negative air chambers several times at different pressure levels as you pumped it up? Volume tokens should not have much effect on the air spring required to set sag. I'm not familiar with the DPX2, but I imagine it would require similar pressure to the DPS shock (roughly your weight).
    Join 43,192
