Decoy assist top speed less than 20 mph
Fx1
Auto WARNING : Possible Duplicate user : "Zero"
Feb 6, 2020
267
203
GB
Wheel diameter can be changed to compensate
Fx1
Feb 6, 2020
267
203
GB
Does STunlocker have the ability to adjust wheel size? My bike seems like I'm going a bit slower than the Shimano display says.
Yes it does.
Change the value by 10% and in theory you will gain 10% speed limit
The Shimano motor decreases the level of assist as you get close to the limit, the idea being that you dont get a sudden drop off as you hit the limit.
Be aware that if you have a problem with the motor, and need to get it warrantied, but have used a third part app to tune it, then you will need to flash the software back to stock before sending it off, as they can tell through the diagnostic software if it has been played about with, and may not warranty the motor if they think it has been derestricted.
IMO if you really want to look at derestricting the bike, then something like the Badass box is a better option as you dont have to change the software, or connect anything to the motor, as it simply tricks the speed sensor it not thinking you are going half as fast as you are, though of course this means the speed displayed won't be accurate, not the distance travelled.
MacRS
7
7
U.K.
Do you have a badass box on your bike ?
i had one for a bit, but I found it reduced the range as you are always using the assistance, so took it off. I am not really so fussed anymore about the limit
524K
