Hi Tooks,
Thanks for the detailed reply. It feels too stiff and like I am floating above the terrain. I adjusted from standard settings which were way off (air pressure was 190PSI).
This was my first ride after adjusting to Fox's recommendations at
SHOCK- 2019 FLOAT DPS and DPX2 | Bike Help Center | FOX the first point Fox suggest (as I read it) was to set the air PSI to your body weight in pounds = 227 PSI (I am 6'4 and approx 103kg's with riding gear). To get 28% sag approx 14mm movement when sitting on bike I need to increase PSI to 330 and then rebound to fully closed according to Fox guidelines (as I read/ understood them). Way to stiff and just not a good feeling.
I have let further air out and increased rebound to 3 and it is starting to feel better. (Note: when I let air our of the chamber on the rear shock, oil also came out. In quick research this is normal. Is that correct?)
More trial and error is required this weekend, based on what you are running I am way off and probably need to go down to 237PSI and maybe 5 clicks from closed on rebound. Thoughts?
Thanks again
