How to turn a bearing into a bushing, just add water.
Thanks for confirming Bearing Man. Sad and worrying to know Brose have done sweet FA to seal their newer 2019 model engines.Yup, don't worry, I was with youIt may look different on the outside...but that's it! Same on the inside.
You don't really notice a slightly stiff crank while pedalling forward, but if you turn your crank arms backwards and feel resistance you may want to dig a little deeper.
The main reason I am writing this post is because of several other posts I have seen on this issue where people with stiff cranks have been advised to "tip oil into the crank" or "just ride until it stops!". The truth is that a stiff crankshaft is usually caused by a dry crankshaft needle roller bearing. This bearing supports the
crankshaft within the sprocket carrier.
The bearing runs directly on the crankshaft and uses the motors crankshaft as the bearing surface, once this surface is damaged, it is GAME OVER!! You can't buy another one and our stocks are limited.
So what happens and why?
Brose have used a needle bearing with two rubber seals built into it. This is fairly common but this is a bearing designed to keep grease within itself, it's not really designed to keep water out, and this is what it's being used for! Once water breaches the seal, the bearing starts to fail, the worse the bearing gets the less effective the seals become, eventually letting water straight through into the motor.
If your bearing is bad then putting oil into it is like shutting the gate after the horse has bolted. All you are doing is filling your motor up with another substance that is not supposed to be in there (makes my life harder when cleaning it all out too!).
Take a look at some of the pictures below if you wan't to see what this bearing is capable of. (none of these motors had been jet washed)
Today while cleaning complete drivetrain I noticed slight rubbing sound (keep volume up or use headphones if you don't hear it) and some unusual/inconsistent resistance while rotating the spider forward - as you can see the cranck bump at specific angle - is this normal or is somewhat connected to the problem you are all talking about here? While I turning crank arm backwards I can't feel much of a resistance, just a bit of a swoosh sound ...
How do you keep the chain etc. clean? Can you post a pic?Had my Levo for three years no .Ridden three times a week ,usually muddy ! Never had a problem .
Secret ? Never wash it !! No point !
Chain cleaner/wet lube chain oil and change chain/both sprockets regularly,How do you keep the chain etc. clean? Can you post a pic?
So how do we prevent this from happening in the future?You don't really notice a slightly stiff crank while pedalling forward, but if you turn your crank arms backwards and feel resistance you may want to dig a little deeper.
I have the same issue with a kenevo, parked up for two weeks and now cranks jammed solid. Will not pedal backwards, going in for a replacement motor with another two years warranty, thats after 900miles riding through shit weather.I have a 2019 Kenevo bought in Nov 2018 and its already had a motor replacement after 6 months. I recently left the bike standing for 2 weeks whilst I was away and the cranks had 'siezed' - i.e. wouldn't freewheel backwards within the motor like normal. After a bit of pedalling forwards backwards they free'd up but now seem to make a small (but audible) scraping sound once per revolution when pedalled backwards. Motor is still under warranty till Nov 2020. The cranks rotate as normal for now. Do you think it's worth pursuing a warranty claim at this point or better to wait as late as possible before the warranty expires - assuming they don't keep 'seizing'?
No 2 year rolling warranty mate just 2 year warranty from date or purchase I have been schooled on this !I have the same issue with a kenevo, parked up for two weeks and now cranks jammed solid. Will not pedal backwards, going in for a replacement motor with another two years warranty, thats after 900miles riding through shit weather.
I bought a hardtail to ride when my Kenevo is in for repair! Kenevo is still the best thing when its working!Think i might go back to a simple hardtail after.
New motor fitted. Apparently it a new 2.2 version. No idea what the changes to this motor are if any
lol yeah could be. Apparently a shipment have just arrived in Australia
Was dying to use that. Hopefully it is an updated motor so they can silence all the hate.lol yeah could be. Apparently a shipment have just arrived in Australia
So would I but I can't find any emtbs that do that!I'd rather have the second best thing that works all the time than the best thing that hardly works!
I thought he advised against adding oil?Thanks Bearing man - Read this and checked - found stiff cranks, chain off and soaked with oil and after a two or three minutes rotating it freed off and feels and sounds OK, no bearing rumble detected
Not sure if I've been lucky and maybe the seal was dry but even though I check and lube regularly I never noticed the problem
So if the bearing do go, what's the fix ???
