Decathlon STILUS Full Suspension Electric Mountain Bike - SRAM SX
there's a bit more info on this (translated) news article:
Google Translate
So, a question for all Decathlon lovers.. Do you go for this 'excellent value for money' interim bike or wait to see what Decathlon release under the Rockrider banner very soon?
Value for money can only get better surely as Decathlon's full sus Rockrider will have to be better than this interim bike.
Yeah, maybe it was lost in the translation, but it was a bit odd for them to say it's just a temporary stop gap bike. I'd possibly be concerned about parts availability / support once the 'real' rockrider appears
I would actually go for this, certainly at the price point, rather than wait.
This is because its a frame being used by other brands so likely to be easy to get spares for in the future, and used the full Bosch suite of parts she say to get spares for that too - its very genericness is actually its biggest advantage in terms of the longer term as it pretty much uses all stock parts.
Quite frankly if you have a sub 3k budget their is nothing that even comes anywhere near it for the money, and nothing I can think of that isn't at least a grand more.
Totally agree.
Buy the bike, go ride it.
The only thing that makes you a better rider is time in the saddle. A couple of degrees here and there on the geometry and a percent or two better performance on a couple of components won't do a thing.
Old motor and new motor are not interchangeable.
Corratec geo chart has no pretty picture to show what the measurements relate to.
been onto decathlon site, bike availlable online 2999
and its taking me through checkout
sorry guys not going any further
Do you have any info if this bike is avaible in Decathlon in other countries than Uk or France ? I have checked in Poland (where i do live), and seems its not (yet?) avaible here.
I tried as paul-g to order it from UK site, and yea, i came to checkout stage. Didnt went further to check if they can ship it to Poland.
Also it could create potential guarantee/service issues. We dont have official Bosch services here, so repairs are managed by bike shop where bicycle was purchased - usually they send damaged units directly to Bosch. Im affraid it will limit my guarantee to "non existing" level if i buy this bicycle from decathlon UK, in case of problems i would need to send bike back to UK. Theres some hope that Decatlon have some "pro-customer" politics and i could deliver damaged bike to Decathlon in Poland, but as for now i dont know anything about such possibility.
have a worl andy and see if the store will get a bike for you
to try.
worth a punt mate
I'm quite far from any store, and they don't seem to have any in stock yet. I can always send it back using thier return policy if it doesnt fit.
Just wondering wether to go Medium or Large. I guess with the sloped top tube, standover height wont be much of an issue.
I think they'll initially just be internet purchased, with in store pickup. As you say, you'll still be able to return it if it's a size disaster :-)
Size wise, it looks like you're at the bottom end of their "large" recommendation. I guess it then comes down to how you plan to use it and what you want from it. The large will be a bit more stable, but the medium will be slightly smaller and easier to flick about - in theory.
Oh wow...I may get one of these for the missus..! Can you retro-fit a 625wh to it?
It seems to be the same frame as the Lombardo, which is the 625, so presumably you'd be able to swap out. I guess it has a spacer with the 500. I think @Doomanic did a thread with the rail showing a spacer with the 500 battery.
I did, but I have no idea if that part is universal or Trek specific.
Copied from decathlons french website...
The STILUS mountain bike is equipped with a BOSCH POWERTUBE 500 Wh battery which guarantees up to 4 hours of autonomy and 2000 m D + (depending on the route and the operating mode). The frame is compatible, without any modification, with a 625Wh battery (700gr more) available on order from BOSCH
Well spotted. They seem to have added a few other bits too :
The sizing guide is different to their other bikes :
M: between 1.60 m and 1.69 m
L: between 1.70 m and 1.80 m
XL: between 1.81 m and 1.92 m
If you are on the border between 2 sizes:
Take the smaller size to favour riding phases (easier to handle bike) and comfort (more straight back).
Take the larger size to favour the pedalling phase with a longer position (position more suitable for performance).
Easy to change battery :
The assembly / disassembly of the battery is done in less than 15 seconds:
1. we slide the protective cover down
2. we turn the key
3. we press the aluminum lever at the top of the battery
and voila.
Wheels :
SUNRINGLE DUROC 40: these wheels have been specially designed for this mountain bike:
- 36mm rims (width between hook), 32 spokes at the front and at the rear, for more robustness and good support for the 2 wide tires , 8 ".
- Through axes in BOOST format 12x148 behind and 15x110 in front, for more robustness
- Aluminum hubs with sealed bearings.
- TUBELESS READY compatible: pre-mounted rim tape; you will need specific PRESTA valves and anti-crevice liquid
SCHWALBE Smart AM 27.5 x 2.8 tires.
The dropper is 120mm.
50mm Stem. 760mm bars. (I cut my Kenevo bars down to 760 recently as the 800's were felling passing trees, the 760's felt like 300's for the first ride but feel great now)
Equipped with the PURION screen
Weight 25.5kg - without pedals.
[QUOTE = "Zimmerframe, poste: 131367, membre: 4350"] La batterie est de 500 Wh.
160 mm avant sur le Rockshox 35.
150 mm arrière sur le Deluxe.
Moteur CX 2020
Freins Sram Guide RE avec disques 200/200.
Decathlon a travaillé avec une entreprise italienne sur le vélo - n'a pas encore déterminé qui.
Sur dirait qu'en France, il ne sera disponible que pour la commande Web, mais l'e-st500 était comme ça au début et vous pourrez le récupérer en magasin. [/ CITATION]
LOMBARDO bike
people we keep reading this article and asking so many questions.
don`t think anyone has bought one
solution
asuming there is 2699 members what say we all donate £1.00
buy a bloody bike, have it tesed then we all know from the horses
mouth
bobs your aunty mary
job done
oh sorry guys for got to include
after test sell raffel tickets £1.00 each to each memeber
lucky winner gets a full sus for £1.00
then you ask where is all that money going to.
SEND ALL £2699 TO CHARITY
As I said somme time ago to a Decathlon store manager. Decathlon is losing the train. This show they are running to catch it with some hybrid/provisory solution.
    676K
