Alternative Grease for servicing the CX seal.
I use a metal hook to rake out the twigs and dirt, then blow it clean with compressed air. But that's only because I have a compressor. But you're right, a brush and sprinkled water is the best you can normally do. If the seal is in place and greased you should be fine.
Also remember, Just because the cheap seals that don't really work that well came free with your grease...you don't have to use them ;)
I’ve always wanted to know why that large silver cylinder on the drive side of the Bosch is never lubricated. In your videos you advise not to even put finger prints on it. Surely without even the thinnest of lubes wouldn’t it suffer from a metal on metal situation? What would happen if you did put a thin lube on it just out of interest?
That part is the freewheel gear and it fits into the large clutch bearing. You can put your fingers on it but any grit or dirt what so ever could badly damage the bearing surface, hence, best not to touch it.
A clutch bearing needs to grip the bearing surface it runs on when it needs to lock the drive. If a high pressure or Teflon grease it may slip or judder (both scenarios are bad). If an abrasive grease like Graphite or Moly grease is used it may also slip and may contaminate plastic gearing.
There is normally always enough grease left in the bearing to "go again". If not? then a suitable grease like the one we use should be applied.
Thanks, I’ve just looked up what clutch bearings are and how they work. They seems to have lots of tiny springs which facilitate the grabbing effect when the shaft tries to rotate in the reverse direction. Clever stuff!
So is this clutch bearing what you refer to as the “main motor bearing” and the one in the direct firing line of water and mud ingress?
No, the main motor bearing is the relatively large bearing that supports the aluminium sprocket carrier and the large plastic drive gear behind the cover. The clutch bearing can be affected when water gets through the right-hand crankshaft bearing.
The blue bearing in the case below is the main motor bearing and the rusty thing in the white drive gear is the clutch bearing. The gear below that is the freewheel gear after water has entered the motor.
Mobil Polyrex™ EM Series
Electric Motor Bearing Grease
Product Description
Super-premium Mobil Polyrex™ EM Series greases are specially formulated for electric-motor bearings. The advanced thickener formulation and proprietary manufacturing techniques provide improved bearing performance and protection for long electric motor life.
Applications
Mobil Polyrex EM greases are recommended by many major bearing and electric motor manufacturers for long-life lubrication of electric motor ball and roller bearings.
Mobil Polyrex EM 103 is more specifically recommended for applications such as vertically mounted bearings, or very large motors where a stiffer grease consistency may be required by the OEM.
Mobil Polyrex EM greases have been shown to be compatible with a number of ExxonMobil lithium complex greases, as well as competitive electric motor mineral polyurea products, as determined by the methodology of ASTM D6185. For specific questions about grease compatibility, contact your Mobil representative.
Key applications include:
• Electric motor bearings
• Fin fan bearings
• High-temperature pump bearings
• Factory-filled, sealed-for-life ball bearings
• Ball or roller bearings operating at high temperatures where low oil separation is required
• Mobil Polyrex EM for ball or roller bearings operating in noise sensitive environments
Please think carefully before putting a different grease in or on your motor.
Many greases might look good for electric motors, but an ebike motor is not technically an electric motor! It has an electric motor inside it, but the thing itself is mostly gears and electronics. This is when a much deeper dive is required before using a different grease.
It should be asked if the grease is compatible with plastic gearing?
Is it dielectric to protect the open electronics on the PCB?
Is it compatible with clutch bearings, high pressure or high performance Teflon, ceramic etc. greases causes many problems.
is it compatible with the standard bearing or gear grease? Aluminium based greases, like a marine grease, can turn lithium based greases back to oil for example.
Is it compatible with NBR O-rings and seals?
Etc, etc.
We spend a lot of our time, cleaning out different greases from motors, where people have bought the best grease money can buy believing it's the best thing that can be used... but if it's not the right grease for the job, you may end up paying the ultimate price!
As a greasing nerd, cleaning & regreasing regularly with the Bosch tacky stuff, I do find the grease degrades quite quickly, discolouring & thinning out noticeably. I've wondered why & the only thing I can think of is heat from either the motor or friction from spinning the cranks but that seems a flimsy theory.
Thinking out loud, back when I used to tinker with motorbikes I used to swear by Hylomar blue, has anyone else used it?
It's a non setting sealing compound LINK
Wondering if it would make a good substitute instead of grease for the external seals, as it won't wash away like grease does.
Not sure how friendly it would be if it did work its way inside the motor though?
Maybe one for the @Bearing Man
I like your thinking but not an ideal product for this application because there are rotating parts involved. Hylomar is a static sealant.
I've long observed the grease Bosch supply isn't especially durable & have wondered about using marine grease or similar with higher viscosity. I guess the dispersal is a function of heat cycles but that is just a guess.
Hence why I haven't done it. The grease could definitely be better but I'm not presumptious enought to think I know more about Bosch stuff than Bosch.
Edit to add, I realise I posted the same thing twice. That's what you get for not reading the thread!
I've been using the RG2 grease and noticed the same, that it seems to thin out after time.
I just remember hylomar being so good, it sealed a leaking fuel pump for years but like you say that was a static situation.
I notice it does come in different viscosities now, my motor will be coming to you in due course so maybe I could gunnie pig it, or maybe I'll just stick to the Bosch grease 😆
While it "maybe" the best grease I think cost is a consideration too.
There maybe a better grease that just isn't financially viable for Bosch to use 🤷‍♂️ just a thought, or maybe you get to a point of diminishing gains with any grease?
I would think Bosch wouldn't care much about the price but would just charge what they need. Someone identified it a while back somewhere & it's just something they buy in & resell in Bosch packaging. I reckon the key point is if you swapped to something else, you're taking a risk unless you know for sure the formulation won't interact negativey with other bits of the motor as noted above.
For me, it's not much of a hardship to redo it regularly but I also recognise that isn't everyone's cup of tea, I'm just the sort of weirdo who likes waving spanners around.
I’ve borrowed this image from a post by Stihldog in the following thread by Rusty MTB;
Bosch Gen4 Seal Service & Grease up
You can see the Bosch Tube of Grease has the details of the manufacturer on it.
RENOLIT CA-LZS 2 M
I had difficulty finding that for sale in the UK.
But the classification is KP2K-30
So one option might be RAVENOL Marine Grease but you might want to buy the grease gun that goes with it.
RAVENOL Marine Grease - 400g Cartridge
Or Performance Line Bearings/ebike motor centre I think suggested Motorex FETT 2000. Its classification or spec is KP2G-30. And no I don’t know the significance of K as opposed to G.
Anyway you can get a nice 850g tub here,
MOTOREX Fett 2000 Long Lasting Waterproof Grease | 850GR Tub
The Bosch Grease is very similar to Motorex FETT 2000
The Bosch grease retails at £1 a gram (it is 20 quid for a 20g tube I think).
But for £22.87 you can get 850g tub of pretty much the same thing. The Bosch price for that would £850.00.
(Though disclaimer - I don't know the significance of K as opposed to G - but I'll guess it ain't much)
But anyway, those two products give us idea of the realistic retail price of the Bosch product.
I do now.
G had a max working temp of 100 degrees C as opposed to 120 degrees for K.
It is just all the KP2K-30 greases I come across are sold in cartridges designed for use in grease guns.
Anyway this page helps explain the Bosch grease spec
LUBRICATING GREASES: DIN 51502 AND ISO 6743-9 -
And it goes likes this......;
RENOLIT CA-LZ
Manufactures Description - High performance, long-life tacky grease based on a special calcium soap. Excellent corrosion protection as well as resistance to water and saltwater. Strongly adhesive, protects from wear even under extreme conditions, very resistant to water wash-out from metallic surfaces.
DIN 51502 Classification is KP2K-30
So the code breaks down as follows;
K – Rolling bearing, anti-friction and sliding surface greases in accordance with DIN 51825
P – (this letter denotes types of additives) For lubricants with active substances to reduce friction and wear under mixed friction conditions and/or increase the stability with regard to the load.
2 – (This number is the degree of hardness) 265 – 295 DIN ISO 2137 (moderately soft – like peanut butter)
K – (max work temperature) +120 degrees C
20 – (minimum work temperature) -20 degrees C
@Bearing Man Hi, Thanksin advance for your help.
I had to lightly clean the freewheel gear and the bearing. Can I apply the same 'Bosch Drive Unit Grease' here? Does this grease go on all parts of CX Gen 2(Plastic-Plastic, Plastic-Metal & Metal-Metal)?
The Bosch motor grease is not the correct grease for the clutch bearing, but it will do the job. And yes, the Bosch grease is good for all gears in the Gen 2 motor.
Just a quick update for anyone reading this thread. Bosch have now released a new type of grease for the bearing seal. It's the same price but half the size! Hopefully it's twice as good (y)
Available here: Bosch bearing seal grease -
I have a tub of this Motorex bike grease for my pivot bearings and headset etc, it claims to be highly water repellant so would it be suitable for the crank seals? Thx.
BIKE GREASE
BIKE GREASE
Yes, Motorex 2000 (bike grease) will work well.
Sorry if I missed it if mentioned before but what about nautic grease, e.g. used for outboard motors?
Definitely not! Many marine greases are aluminium based and can react with bearing grease thickeners to turn it back to oil... This is why popping some behind the hubcap of your boat trailer is a bad idea, a few months time, all your wheel bearings fail.
Thanks for your reply. It doesn't actually say Motorex 2000 on the jar label, just Motorex Workshop Bike Grease. BIKE GREASE And a search for "Motorex 2000" on the Motorex website doesn't provide any specific result other than a number of "Bike Line" products including this Workshop Bike Grease. So I'm guessing they've just dropped the "2000" in the nomenclature?
Thanks for your input to this forum and your very useful info/advice. I hadn't realised there were so many different types of grease with specific properties for specific uses and it's easy for us DIYers to make well intentioned but bad decisions when maintaining our bikes!
    668K
