After 4 months of abuse and just over 900k's the Kenevo (1.3, a proper one, not one of those new "pretty" ones
Like, many I've meticulously measured the chain regularly using the "eye" method .... yup, looks the same length.
To be honest, I've never been sure which chain measuring tool to buy. They all appear flawed and to get a good grasp of what's going on, you'd need to take several measurements. Though I think I've finally sussed that one.
The chain of choice for winter abuse :
SRAM NX PC-1110
SRAM NX PC-1110 11 Speed Powerchain | Chain Reaction Cycles
At £9, it's strong, long lasting and cheap enough that you can buy several for the price of some of the more expensive offerings and just change more frequently, if you need to. Suggested by @Kiwi in Wales .. so a huge huge thanks for that.
I also worked out, it's the most accurate and cheapest chain measuring tool. Just take off your existing chain every now and again for a good clean, lets face, it actually only takes 2 minutes. Hold your chain up to your "new" measuring chain and you can see how much it's stretched ! Your "measuring chain", unlike other chain measuring tools, has a built in replacement chain which you can use to replace your stretched chain when it's time.
Today's muppet lessons learned... Other than the cheapest, best, most accurate and with a free replacement chain - chain measuring tool.
I couldn't undo the quicklink, no matter what I tried. So reverted to a pair of pliers squeezing one outer link end at an angle with the opposite outer link end. Slid apart in seconds. (I know you can use your shoelace, but that presumes that a: you can do shoelaces b: you weren't wearing rigger boots. )
I then couldn't get the new link to close up ?!?! brake on, weight the pedal etc etc .. nothing .. doh ... So I reverted to what seems to be one of my most used bike tools .. the circlip pliers ... click .. perfect .. Just wondering now if I could have used the pliers on opposite link corners in the same way I took it off ???
