Alright, my Levo isn't for sure the most modded one, but I've tried to concentrate to the most relevant updates.
As soon as I got the bike, I knew that I will update the suspension; the stock Revelation with its Motion Control damper just doesn't do justice to the rest of the bike. Hence, I ordered the new Charger 2 damper and updated also '19 model DebonAir spring (160 mm) for it. I also changed the seals into SKF's and assembled everything with SlickHoney. That meant that the fork was as good as it can be: plush but rigid, sensitive but doesn't bottom out too easily. I'm running with 70-72 psi and 1 token.
When I got the frontend working nicely, I noticed that there was room for improvement in the rear as well. In came the Cane Creek Double Barrel coil inline, which I ordered from TF Tuned in the UK. I initially got 600 lbs spring for it, but I changed that to 550 lbs, which means 31-33 % sag under me (87 kg with gear). It took few rides to get the shock tuned up correctly as it has high-speed and low-speed damping adjustments for both compression and rebound, but now everything is setup so that I can just plough through even the most gnarliest single tracks. Plushness is my 1st priority, so the shock will bottom on any bigger drops, but no way harshly so I'm happy.
Other minor updates are EBC brake pads (green stuff) front and rear to stop brake squaling, better grips, custom-made carbon bash plate and a short front fender. I also use Garmin GPSMAP 62s on my handlebar to show topo maps during my rides. Tires are tubeless of course. Next up are 150 mm cranks.
Some bearded guy photobombed me, when I was taking a photo of the bike, sorry about that
I live close to Helsinki, in Finland, next to Baltic sea coast. There are no lifts or shuttles to take me up to mountains (as we don't have any mountains here), but single tracks, rocks and roots we do have.
