Post your modded Levo’s!
2019 Levo base - Upgraded with Pike RCT3 forks, Guide brakes, Ergon Comp Ti rail seat, X-Fusion Manic dropper, Nukeproof Carbon bars, DMR Death Grips, Raceface Chester pedals.
I got the weight down to just over 47lbs (21.5 kg) but then put on a Butcher Black Diamond rear tire - now weighs 48.2lbs (21.9kg). I may upgrade wheels next, but in no rush - maybe 700W battery too!
Not mine but it certainly is modded.........
quite a collection of mods ...looks like
C/Brothers pedals
DT swiss rims
Olihms Fork and shock ?
looks like a sram eagle cluster , love to know how that goes on the Levo
magura brakes
custom paint
wonder if Specialized will put limited edition like the Troy Lee Designs edition
Alu Comp XL
700 w battery
Factory 36’s @ 160 mm travel - Grip 2
Factory DPX2 210 x 55 @ 158 travel
Renthal Fat Bar
Renthal Apex Stem
HT pedals
Drops AMM protection
Firstly would like to say that bike out of the box is 100% OK out of the box if you just trail ride. I’m a big unit and the Revelation forks were basically annoying me. I hated the squelching sound the damper makes. (Mouse in the house ) I looked at converting to Pikes and while I was there increasing to 160mm travel. Was going to cost around 600 Aussie. And I would still have pikes. Discussing with local suspension people who were great and worked out fairly quickly I could sell my RS Revelations and with the 600 could own some grip 2’s. No brainer really. ( forks sold easily )
So now I would have some gold up the front. Better balance that out and get the DPX2 and throw some more travel in while I’m there. Shop gave a further 10% discount for buying a package. Win. Found nothing wrong with the original shock, just balancing out the look. Still have not sold the shock.
The bars and stem were changed for no reason and are just like the drops protection, just to make the bike mine.
Alu Comp. why? Not a carbon fan and so saw no worth in the upgraded specs if I decided to change out any components. LBS did a great deal and basically got the bike for the same price as the base model but now had the dropper post that I preferred. And with the saved cash I push asked the 700 watt battery. So for the same price as the comp I had the 700 watt battery and still own the 500 watt as well. Not selling it and it’s there if I want to ship a battery overseas and then fly the bike, or if I want to go away for a big weekend and have no charging capability.
So that sit and this is what it looks like.
Ohhh yeah, changed stickers on the fork. The orange was a bit too out there for me
Nice! decals look great, Are these original Fox Heritage decals in silver?
I had some fun last week “modding” my 2020 Comp Carbon, yep you read that right, 2020 Comp CARBON. Love this bike!
Tell me what you think guys.
COMP CARBON 2020 Gunmetal
Fox Factory 36
DPX2 Factory
S-Works 3.8 carbon bar
Deity 50mm stem
Ergon SM E-Mountain saddle
Alu One UP pedals
ODI Rogue grips
Alu Specialized dropper remote lever
Fidlock magnetic cage / YT bottle
Levociraptor
DHR 2.4
DHF 2.5
Slik Fox & Roval decals
Wanted to share my color matching attempts on my 2019 Levo Comp Carbon:
- Lyrik Ultimate (160mm travel, 42mm offset)
- Industry Nine A35 stem (50mm)
- Deity Speedway 35 handlebar (780mm)
- Ohlins TTX22M (TFTuned Setup)
- Ergon SM saddle (Red)
- Ergon GE1 EVO grips (Red)
- Hope Accessories (Red)
- Specialized 700WH Battery
- DMR Vault Magnesium Superlight V2 Pedals
- Full Invisiframe & Custom Decals
I had some fun last week “modding” my 2020 Comp Carbon, yep you read that right, 2020 Comp Carbon. Tell me what you think guys.
Fox Factory 36
DPX2 Factory
Deity 50mm stem
Guide RSC brake levers
Alu One UP pedals
ODI Rogue grips
Fidlock bottle
Levociraptor
SDG roval decals
Slik Fox decals
Next mod: Fox Kashima dropper :geek:
Not many of those around!
Alu Comp XL
700 w battery
Renthal Fat Bar
Renthal Apex Stem
HT pedals
Where did you get the top bar decals from?
Thought I’d post up a few pics of my new Levo build.
Built up with help of MB Cyclery in Haslemere.
Started life as base 2020 aluminium Levo as we pretty much just used frames! Spec below with help from Deity/Praxis/Michelin as be racing this next year, but the main feature is the raw alloy finish which I did for the three bikes we built. Can go into details on the process if any interest? Hope you like it!
Spec highlights:
Raw finished Aluminium Levo
Ohlins RFX 160 Coil fork & Rear shock
Sram XO rear mech/shifter
Shimano XT 11spd cassette/chain
Deity Bars/Stem/Saddle
Praxis carbon cranks
DMR death grips & flat Brendog Ice pedals
Stock Roval wheels with Michelin tyres (currently Muds which are exceptional in wet/muddy conditions despite my reservation on their 2.25 width)
Stunning bike!!!! Love it!!
How did you get the raw frame??
It would be nice to see more details of the bike and of the process also...
What protector are you using in the downside of the frame?
Are you using 29" front and rear?
Thanks guys?
It was a long old process, not sure it financially viable as took about 12+ hours to do.
Rough details are dip to strip oe paint. Machine sand the acid etched raw frame, then hand sand with various grades to smooth and finish with ultra fine 3m scotch pad. Then satin lacquer, fit decals and finally Invisiframe kit.
We did three, my Ohlins build, a Factory orange Fox build and Red Rockshox build?
Thanks guys?
Waw!!! Such a craftmanship work!!!...the result is TOP!!!
What about the rockguard??...also hand made?
My 2017 Levo Fattie Large frame brought second hand just love it
Mods
Shorter Head Stem
Spank Spike Vibrocore Alloy Bar
Miranda 155mm Cranks
Front fork 160mm air tube installed
High and low-speed compression adjusters installed on the other side of the fork
Flux Light
Shorter seat dropper because I'm a short arse
34 tooth front ring gear
Floating Hope rotors
Modified mud guard to help protect the motor from inhaling dirt
Oneup multi-tool installed in the head stem
AMS transfers
Fly6 Camera set up below the seat
Running the Belevo App
Apart from that its pretty original
Would love to upgrade to the Sram XX1 Eagle AXS 1 X 12 wireless gear set just have trouble justifying the dollars
    Join 43,210
