• Warning!!
    UK Pedelec Law
    Worldwide Laws
STUnlocker (ex Shimano STEPS Unlocker) Android & Windows App for derestriction/market change and etc
vadII
764
564
Earth
Where did you get this address? It's not correct. Correct one is STUnlocker.com
Hi vadII
Is there a problem with your address ( [email protected] ) I have sent 2 emails with the same result
Regards
Garrit
Delivery incomplete
There was a temporary problem delivering your message to [email protected]. Gmail will retry for 23 more hours. You'll be notified if the delivery fails permanently.
AndreaFx
20
Milano (Italy)
Question: If I unlock the speed limit with firmare 4.3.2 then I update to firmare 4.7.1......speed limit remains unlocked o the new firmare overwrites the config?
vadII
764
564
Earth
Try it. Didn't test it. Firmware does not overwrite settings.. But, I think, the new FW logic will not use that limits.
Danny_bird
Essex, UK
Yes it’s weird, I don’t have anything?? I have sent it off from 2 different email addresses? Sent it 3 times now and got nothing???
It is an automated response or does someone physically message you back??
Thanks guys
Damosa
España
Hello, I want to buy the license to use 32kmh in Spain, but I have doubts if it covers shimano warranty if one day I have a motor problem, does the app leave a trace when modifying speed settings etc?
Stanny_uk
82
62
Uk
Can I change to America restriction with android St unlocker via Blue tooth or is it a window and cable job
cuencun42
valencia
Hola buenos dias soy novato en el foro, adquirió hace dos semanas un e-bike con motor shimano e8000 y compró la aplicación st unlocker para android para poder modificar asistencia etc y ahora lko que queria es cambiar el mercado de europa a estados unidos para que la asistencia llega a 32 km / h pero no se donde obtener la licencia, ni como instalarla.
Me podriais ayudar? y otra pregunta ¿cuánto vale la licencia y dónde obtenerla?
Un saludo y gracias de antemano
PD: mi motor esta actualizado a la ultima version de fireware
cuencun42
valencia
hola otra vez esta tarde compró la licencia pero no pude instalarla porque soy bastante torpe por lo visto. Estoy esperando que me la vuelvan a enviar a ver si puedo instalar porque cuando inteto instalarlo me sale esto. Alguien me puede ayudar por favor estoy bastante frustrado
StuE
282
298
Leeds
Hola de inglaterra
Ocurrió este problema al hacer clic en el enlace del correo electrónico de Stunlocker?
StuE
282
298
Leeds
es el texto en azul, la aplicación debe abrirse cuando selecciona esto y la licencia se aplica automáticamente
MassDeduction
49
25
Victoria, BC
Is there a simple way to downgrade to 4.3.2 ?
Maybe a function of Steps Unlocker or eMax can do that ?
As far as I know, neither STePS Unlocker nor eMax provide that function within their software. I believe eMax provides instructions and insistence with the downgrade (but their instructions require you to have Shimano's E-Tube Project hardware which is pricey).
vadII
764
564
Earth
It's possible to downgrade using a smartphone (without any additional hardware). You can find instruction on Net. Someone copied my instruction to a special site before it was removed from www.stunlocker.com due Shimano demand
Coopers
15
9
Another happy customer here. Awesome app, well worth the money! Thank you Vadll!!!!!!
FYI, I'm running the E8000 motor, E8010 battery with SC-E6010 display (had to use a junction A to gain bluetooth connectivity) and stock 4.7.1 firmware.
524K
