GARMIN EDGE 520 /530 : what rider/bike information ?
bronces
France
Hi,
I am looking for a computer, leaning toward the Garmin 520 or 530.
1°) Does it work’s with the new 2020 Turbo Levo ?
2°) Its not clear for me, if some information such as cadence, exact battery percentage
Speed distance… and other present in Mission Control, came directly.
So - If someone know what rider/bike information are given by Edge, I would appreciate it.
Thank's
Hi,
Thank's
Have you considered to use BLEvo? If interested see my post in BLEvo thread of today with screenshots.
Yes of course. BLEvo is great, but I would prefer only one display in the cockpit, and not my phone.
1) With 2019 Levo Edge 530 works fine
2) It shows ”normal” edge info speed, distance, pedal power, candade etc. With e-bike field (IQ data field) it shows assitant mode and battery status.
You‘ll get rider-power, speed and cadence from your Levo as „normal“ ANT+ sensors.
If your Levo is speed-manipulated you‘ll need a Garmin hub-speed-sensor extra to get correct speed.
Levo‘s battery- and mode-state you‘ll get via IQ-datafield by Jan Capek:
Ebike Field
I use an Edge 1030 and all works flawlessly.
Further to the above discussion, does anyone know if the Apple watch can transmit HR data to the Edge 520/530?
It can’t, you will have to use a Hrm belt.
Karsten
Ebike Field
I think bold one is not correct - no extra hub-speed-sensor is needed. In Garmin devices you can use Levo speed sensor (which will only transmit wheel pulses) and define your own wheel circumference in Garmin so the correct speed is displayed. I have it like this with my Garmin F6X watch and I think with Edge 530/830 it should be the same/similar. Anyone can confirm?
Yes, you‘re right. Just did a test with Levo 2019 and Edge 1030. Setting of wheelcircumference in sensor-info does influence the speed displayed!
    675K
