Couldn’t seem to find presets on the apple app
Thanks for your reply,In iOS app this function is not yet developed
Unable to download the windows application. The link which is sent says it is invalid.
Can you post a direct link
It's not changeable by unknown reasons. I've released version before, but no one was able to change itHi vadll, is there any chance of a new feature to adjust the power output for the walk function? Many thanks for the awesome product
This is a old screenshot, but I would say that with e7000 - dont worry about battery health
Out of interest, have you found that your range is still accurate? Cheers Mike
Why do you have the e7000 display on your bike?
Yes, that is similar to eMax's limitations. Shimano have made changes to their firmware so it's harder to hack. Firmware 4.3.2 or earlier can be completely unrestricted but above this the only method is to change region to USA 32kph and/or change the wheel circumference.
I've not wanted to downgrade my firmware so I've swapped mine to USA 32kph and I've reduced the wheel circumference by 10%. This effectively moves the limit from 25kph to 35kph. On the trails, 25kph was frustrating and left me wanting a little more I'm happy with this for now, it's a decent increase and my speed/trip metre are only slighly altered by the 10% change.
I am interested to try the power limit changes. After speaking with the creator of eMax he doesn't allow this in their app yet as they say it's detectable and voids warranty. Eplus flash unlocks the power limit to 550w. I am unsure if this is a "safe" limit they decided on? Though i would assume if Shimano have the option to turn it up to 600w the drive unit should be capable but they have probably limited it to 500w for longevity.
If the e8000 power can be lifted to 550 or 600w that's a cool 10 or 20% increase.
So, I have tested the STEPSUnlocker - thanks a lot to Vadll for the great program and sending a free valid licence key!
I had 4.6.1 firmware and modified to US version (32km/h) and increased power in Boost mode to 600W yesterday which worked perfectly on the first run.
This morning I had a long test ride with the bike and after approx. 30 minutes in hard terrain, my motor stopped working and the display switched off in middle of riding the bike.
The motor was quite hot at this time, so I waited some minutes.
I tried to restart and the display then only showed the initial "Shimano steps".
Also additional attempts failed...
After walking quite a long way home with the bike, I then tried to access with STEPSunlocker which failed.
Then I tried to connect with eTube from Shimano and this program detected a broken drive unit (DU) and also could not connect to the motor - all other components were shown (derailleur, display, switches)
So I went to my dealer and he asked me quite suddenly if I had made "any modification" on my bike. Because I know my dealer quite well I told him that I used the tuningtool and he told me that the motor maybe could get broken due to the higher power limit.
Unfortunately we could not reset the power limit back to the old, original value, because we could not connect any more to the system.
So my dealer tries to get a new motor from Shimano and the motor is aready dismounted from the bike and on the way to Shimano, but for sure this is not the thing we expected.
So I hope that I will get a repaiered or new motor (on warranty?) and hopefully not have to wait that long...
Hope this does not happen to somebody else...
Software works perfect for me. I would say it's easier to use than emax/freemax/minimax which is annoyingly split into 3 different programs you have to download.
All the parameters work and are easy to change. Did 28km of trails yesterday and tested the motor out with the 500w limit increased which provided a nice little boost in power. Battery range great, and with the bike in trail mode it's still very smooth and easy to control.
