E-150 2022
British engineered low-CoG full-power eMTB - Bosch CX Gen 4, 625Wh PowerTube and a slim 6061 alloy chassis.
The Whyte E-150 2025 (gold spec lists 2024 model year) is the British brand's discontinued full-power trail eMTB, built around the Bosch Performance Line CX Gen 4 motor (85 Nm, 250 W rated, 600 W peak, 2.9 kg) and a removable 625 Wh Bosch PowerTube battery. The 6061 hydroformed aluminium frame uses a 4-bar layout with 160 mm front and 150 mm rear travel. Head angle is a properly slack 64.0°, claimed weight 24.77 kg, and UK base price was £5,250. Now discontinued as Whyte's mid-tier full-power offering, but the E-150 has built a notably strong long-term reliability story on the forum — @Tonytank is still riding his original V1 at "approximately 7,000 miles" total, and @raymondo reports "9,000+ miles on 3rd motor" on his original E-150 — exceptional ownership data.
Drive system and range. The Bosch CX Gen 4 produces 85 Nm of torque and 600 W peak. While now superseded by the Gen 5 (120 Nm), Gen 4 remains a refined, well-known unit with the full Smart System ecosystem — Kiox display, Flow app integration and over-the-air firmware updates. The 625 Wh PowerTube battery is removable for off-bike charging via a clever underside-loading design. @Clubby achieved "850 miles range on Whyte E-150 with 625 Wh battery" — strong long-term efficiency. Expect 1,000-1,400 m of climbing per charge in trail mode. Compatible with the Bosch PowerMore 250 Wh range extender for big-day rides.
Geometry and handling. A 64.0° head angle is squarely modern-trail/enduro. Reach progresses S 445 mm, M 470 mm, L 495 mm, XL 520 mm — generous modern sizing with 25 mm steps. Chainstays grow with size: S 443 mm, M 445 mm, L/XL 450 mm — meaningful for weight distribution. Wheelbase opens 1,243-1,318 mm. 29in wheels front and rear (no mullet option in the gold spec). Whyte's signature low centre of gravity comes from the underside-loading battery design — battery weight sits low and central in the frame.
Build and value. The base trim at £5,250 includes RockShox Zeb Select fork, RockShox Deluxe Select+ shock, SRAM Code R four-piston brakes and SRAM X01 Eagle drivetrain — a competent build with solid foundations. Higher trims with Hope brakes, Fox Factory suspension and SRAM Eagle Transmission AXS were also offered. @The EMF recommends the Hunt E-Enduro wheelset as a high-value aftermarket upgrade: "bombproof and excellent value, used on a Whyte E-150 RS". The bike is now discontinued — current pricing for 2024 stock at clearance dealers should be 20-40% below the original £5,250 RRP.
Community-verified strengths. Long-term reliability is overwhelming. @Hobo Mikey's E-150 RS is "five years old on same battery and same motor. Only done 2000 miles with one careful owner". @Tonytank: "Original battery and 2nd motor total of 7,000 miles" with Hope wheels and discs as upgrades. @r2wtrials is on "3000 miles ... still on original motor and battery". The aluminium chassis is genuinely durable, the underside-loading battery system has held up well, and Whyte's British design ethos shines through in the engineering polish.
Caveats and known gripes. @Mikehorti notes "Whyte e-150 cable routing requires motor cover removal to access tight routing area" — a fiddly maintenance penalty. The Bosch CX Gen 4 is mid-pack against the latest 120 Nm Gen 5 motors. 24.77 kg is mid-pack rather than light. @raymondo reports his original shock is "getting tired" after 9,000 miles and his forks needed rebuilding to 160 mm — normal wear on a high-mileage bike. As a discontinued model, replacement frame parts and proprietary linkage hardware will become harder to source over time. The 625 Wh battery is smaller than 750-800 Wh rivals at the price.
Verdict. The Whyte E-150 is for the rider who values long-term British-engineered durability, a properly modern 64° trail/enduro geometry, removable Bosch CX Gen 4 power and Whyte's UK dealer network at discounted end-of-line money. It is not for buyers who need the latest motor parity, riders chasing the lightest trail eMTB, or anyone outside Whyte's UK-and-Ireland dealer footprint. Production status: discontinued. Whyte has moved on through the Stag and Karve platforms with refreshed motors and updated chassis architecture.
Frame
6061 hydroformed multi-butted T6 aluminium frame with 2.7mm thick downtube, tapered headtube, low motor-and-battery weight distribution (battery slides in from underside), 150mm rear travel, 29" wheels
| S | M | L | XL | |
| Reach | 445 mm | 470 mm | 495 mm | 520 mm |
| Stack | 612 mm | 622 mm | 632 mm | 642 mm |
| Chainstay | 443 mm | 445 mm | 450 mm | 450 mm |
| Headtube Angle | 64° | 64° | 64° | 64° |
| Seattube Angle (eff) | 77° | 77° | 77° | 77° |
| BB Drop | 35 mm | 35 mm | 35 mm | 35 mm |
| Wheelbase | 1243 mm | 1268 mm | 1293 mm | 1318 mm |
| Front Centre | 800 mm | 823 mm | 843 mm | 868 mm |
Trims · 1
RSX £7,999 | |
| Motor | Bosch Performance Line CX Gen 4 · 85 Nm |
| Battery | Bosch PowerTube 625 · 625 Wh |
| Travel F/R | 160/150 mm |
| Frame | Aluminium |
| Fork | RockShox Lyrik Select+ 150mm |
| Shock | RockShox Deluxe Select+ |
| Headset | FSA No. 69/56/SRS with sealed angular contact bearing cartridges |
| Stem | Whyte Trail full CNC, 32mm extension, 35mm bar bore |
| Handlebar | Whyte Custom 6061 alloy, 20mm rise, 35mm bar bore, 800mm wide |
| Grips | Whyte Enduro lock-on |
| Saddle | Fizik Terra Aidon, 145mm wide, Wingflex |
| Seatpost | Whyte drop.it II Adjust, 30.9mm |
| Brakes | SRAM Code Bronze Stealth, four piston hydraulic, 200mm rotors |
| Rear derailleur | SRAM GX T-Type AXS, 12 speed |
| Crank | Whyte 155mm ISIS arms with SRAM GX Gen4 direct mount 36T chainring, T-Type |
| Shifters | SRAM AXS Pod, right, MMX, 12 speed |
| Cassette | SRAM XS-1275, T-Type, 10-52T, 12 speed |
| Chain | SRAM GX T-Type, 12 speed |
| Drivetrain | SRAM GX 12-speed |
| Wheels | Alloy hubs (front 15x110mm Boost 28h, rear 12x148mm Boost 32h) with DT Swiss New Champion 2.0mm spokes, Whyte TeXtreme Innegra carbon Trail rims |
| Tyres | Maxxis Minion DHF EXO TR MaxxGrip 29x2.5 front / Maxxis Dissector EXO+ TR MaxxTerra 29x2.4 rear |
| Weight | 18.9 kg |
| Price | £7,999 |
Rides similarly
Spot a mistake?
