Bike Finder · Trek
Trek Fuel EXe
Trek
Fuel EXe 2025
CurrentLightweight eMTBLegacy · 2/10iFreshness 2/10
Lightweight TQ HPR50 (50Nm/360Wh) trail eMTB
Motor
TQ HPR50 · 50Nm · 300W
Battery
TQ HPR50 360 · 360Wh
Travel F/R
150/140mm
Wheels
29F/29R (MX compatible via Mino-Link)
Frame
Carbon front, aluminium rear
Weight
18.93 kg
Price
From £3,195
View the Trek Fuel EXe on Trek’s site
Trek Fuel EXe 2025
From £3,195
EMTB Forums verdict
The Trek Fuel EXe 2025 is the brand's lightweight trail eMTB, a carbon 4-bar chassis built around the TQ HPR50 motor system. Headline numbers: 150 mm fork, 140 mm rear travel, TQ HPR50 at 50 Nm and 300 W peak (1.85 kg, one of the lightest credible bike motors anywhere), 360 Wh removable TQ HPR50 360 battery, 64.5 to 64.8 degree head angle (size-specific), reach 428 to 530 mm across five sizes, 19.61 kg claimed weight and £4,500 base price with £3,195 entry on the 9.7 trim and £11,000 for the 9.9 XX AXS. The community verdict from @CrashMaster, who rides a Fuel EXe alongside his partner's Orbea Rise M10, is "I really like the power delivery of the Fuel, it is very natural and engages and disengages very smoothly", while @The Reverend calls it "supremely strong and fit" climbing in low/eco.
Drive system and range. The TQ HPR50 is the German motor's defining product: 50 Nm, 300 W peak, 1.85 kg, and famously near-silent under load. The 360 Wh battery is removable, and the platform supports a TQ Range Extender for additional capacity. @Bullit reports the factory settings (Eco 100 W, Trail 200 W, Turbo 300 W) achieve roughly 26 km range and 900 m elevation gain with consistent riding style. @MamboN5's 500 Wh aftermarket battery project documents Molicel M35A cells in the stock pack, with rider-led aftermarket capacity upgrades possible. The TQ motor's silence is the headline differentiator: @Rob Rides EMTB's TQ comms confirm the "very low assist sprag clutch peculiarity" has no performance impact.
Geometry and handling. Trek's headline is its 5-size run with the unusual 23" XL frame at 530 mm reach and 452 mm chainstay, a 12 mm jump in rear-centre versus the standard 440 mm fitted across 15.5" to 21.5". Head angles range 64.5 to 64.8 degrees and wheelbase scales 1188 to 1330 mm. The 23" at 1330 mm wheelbase is properly long, catering for taller riders that most rivals miss. @Emailsucks98 at 175 cm sized up to L with a mullet rear wheel and shorter stem, suggesting the platform takes sizing-up well.
Build and value. Three trims. The £3,195 9.7 is the entry value pick at 19.1 kg with a basic build. The £4,500 base is the volume model at 19.61 kg. The £11,000 9.9 XX AXS is the flagship at 18.9 kg with SRAM XX Eagle AXS T-Type. Standout choice is the consistency of the 19 kg-class weight across the range. Questionable point flagged by @vapeuz: a "2025 model purchased but contained 2023 components", an inventory-mismatch story worth confirming at delivery.
Community-verified strengths. First, motor refinement: @CrashMaster rates the Fuel EXe's power delivery as more natural than the EP8 RS on the Rise sibling. Second, the platform supports significant rider modification: @shure2 documents the eXTenderMod adapter for Ego 2.5 Ah aftermarket batteries giving 34 to 38% extra range. Third, the multi-purpose chassis: @Stihldog documents 5 to 6 minute wheel swaps between 2.5" Assegai mountain trails set and a pavement set, making the bike a genuine dual-purpose tool.
Caveats and known gripes. Reliability has a flag: @Jujujuice's 9.8 XT had a speed sensor failure within 30 days, with the LBS replacement not curing the issue on his bike but the same sensor working on a different Fuel EXe, "suggesting inherent bike-level fault". The 360 Wh native battery is small by 2025 standards. The platform was originally launched at the 50 Nm/300 W spec which now sits below the emerging TQ HPR60 (Norco Sight VLT TQ, Trek Fuel+ TQ) by 10 Nm and 50 W peak. The motor's "very low assist sprag clutch peculiarity" produces a slight clicking under low-power riding per @Rob Rides EMTB.
Verdict. The Fuel EXe is in current production and remains one of the most refined lightweight TQ HPR50 trail eMTBs on the market. Buy it if you want a near-silent, sub-20 kg trail eMTB with proper Trek build quality, the 5-size run including a genuinely long 23" XL, and the TQ aftermarket ecosystem including range extenders and 500 Wh community projects. Look elsewhere if you want the newer TQ HPR60 (60 Nm), full-power 85 Nm-plus, or a 600 Wh-plus battery as standard.
💬 Forum discussion
Trek Fuel EXe Megathread!
4.3k replies · 1146.1k views · last reply today
Join the discussion →
“We’re getting ready for our annual fall trip to Utah and Colorado and are excited to take two new Trek Fuel EXe “Special Edition” bikes this time. my “EXe 9.7 Colorado” mrs levity’s “EXe 9.7 Utah””
— levity · ♥ 19 · most-liked post
OWNERS’ REPORT
Trek Fuel EXe / Fuel+ — what owners actually know
8,181 posts · 799 owners · data through Jun 2026
8The creak complex: factory under-torque and assembly QC · typical onset: First 200km
6Integrated headset: poor cups, missing seals, and two bearing-seat frame failures · typical onset: Creaks early; the seat failure at ~2,500mi
4Lower shock eyelet play + fragile proprietary shock bolts (launch-era) · typical onset: From new (launch-era builds)
2,000 miles: 'I haven't had any issues whatsoever on the bike.
Inside: the community setup plate · numbered field notes · the used-buyer checklist.
Read the full owners’ report →
Bike geometry diagram
15.5"17.5"19.5"21.5"23"
Reach428 mm453 mm483 mm508 mm530 mm
Stack620 mm629 mm629 mm638 mm665 mm
Chainstay440 mm440 mm440 mm440 mm452 mm
Headtube Angle64.8°64.8°64.8°64.8°64.5°
Seattube Angle (eff)76.8°76.8°76.8°76.8°76.4°
BB Drop39 mm39 mm39 mm39 mm35 mm
Wheelbase1188 mm1217 mm1247 mm1276 mm1330 mm
Headtube100 mm110 mm110 mm120 mm155 mm
Standover726 mm727 mm733 mm753 mm764 mm
Front Centre748 mm777 mm807 mm836 mm878 mm
Trims · 6
9.7
£3,195
8 XT
£5,500
9.8 GX AXS T-Type
£9,199
9.9 X0 AXS T-Type
£9,600
9.9 XX AXS
£11,000
5 (Alloy)
MotorTQ HPR50 · 50 Nm · all trims
BatteryTQ HPR50 360 · 360 Wh · all trims
Travel F/R150/140 mm · all trims
FrameCarbon (8.x/9.x) / Aluminium (5) · all trims
ForkFox Float 36 Rhythm, EVOL air spring, GRIP damper, 44mm offset, Kabolt X thru-axle, 150mmFox Rhythm 36, Float EVOL air spring, GRIP damper, tapered steerer, 44mm offset, Boost110, 15mm Kabolt X axle, 150mm travelRockShox Lyrik Select+, DebonAir spring, Charger 3.1 RC damper, tapered steerer, 44 mm offset, Boost110, 15 mm Maxle Stealth, 150 mm travelRockShox Lyrik Ultimate, DebonAir+ w/ ButterCups, Charger 3.1 RC damper, tapered steerer, 44 mm offset, Boost110, 15 mm Maxle Stealth, 150 mm travelRockShox Lyrik Ultimate, DebonAir+ w/ ButterCups, Charger 3.1 RC damper, tapered steerer, 44 mm offset, Boost110, 15 mm Maxle Stealth, 150 mm travelRockShox Recon Silver, Solo Air spring, Motion Control damper, lockout, 42mm offset, Maxle Stealth, 150mm
ShockFox Float X Performance, 2-position compression lever, 205x60mmFox Performance Float X, 2-position damper, 205 mm x 60 mmRockShox Super Deluxe Ultimate AirWiz, RCT2 damper, 205 mm x 60 mmRockShox Super Deluxe Ultimate RC2T, 205x60 mmRockShox Super Deluxe Ultimate, RCT2 damper, 205x60mmX-Fusion Pro 2, 2-position damper, 205 mm x 60 mm
HeadsetIntegrated cartridge bearingsIntegrated cartridge bearingsIntegrated cartridge bearingsIntegrated cartridge bearingsIntegrated cartridge bearings, 1-1/8in top, 1.5in bottom
StemBontrager Elite, 45mm length, 0 degree, 35mm clampBontrager Elite, 35 mm, 0-degree, 45 mm lengthBontrager Line Pro, 35 mm, Blendr-compatible, 0-degree (length size-dependent)Bontrager Line Pro, 35 mm, Blendr-compatible, 0-degree, 35 mm lengthBontrager Line Pro, 35 mm, Blendr-compatible, 0-degree, 35 mm lengthBontrager Comp, 31.8 mm, Blendr compatible, 7-degree, 50 mm length
HandlebarBontrager Line alloy, 780mm width, 27.5mm rise, 35mm clampBontrager Line, alloy, 35 mm, 27.5 mm rise, 780 mm widthBontrager Line Pro, OCLV Carbon, 35 mm, 27.5 mm rise, 780 mm widthBontrager Line Pro, OCLV Carbon, 35 mm, 27.5 mm rise, 780 mm widthBontrager Line Pro, OCLV Carbon, 35 mm, 27.5 mm rise, 780 mm widthBontrager Rhythm Comp, alloy, 31.8 mm, 15 mm rise, 750 mm width
GripsBontrager XR Trail Elite, nylon lock-onBontrager XR Trail Elite, nylon lock-onBontrager XR Trail Elite, nylon lock-onBontrager XR Trail Elite, nylon lock-onBontrager XR Trail Comp, nylon lock-on
SaddleBontrager ArvadaBontrager Arvada, hollow chromoly rails, 138 mm widthVerse Short Comp, steel rails, 145 mm widthVerse Short Pro, carbon rails, 145 mm widthVerse Short Pro, carbon rails, 145 mm widthBontrager Arvada, steel rails, 138 mm width
SeatpostBontrager Line dropper, MaxFlowTranzX JD-YSP39, internal routing, 34.9 mm (travel size-dependent: 100/150/170 mm)Bontrager Line dropper, MaxFlowRockShox Reverb AXS, wirelessRockShox Reverb AXS, wireless, 34.9 mm (travel size-dependent: 100/150/170 mm)TranzX JD-YSI-22PLQ, internal routing, 34.9 mm (travel size-dependent: 100/150/170 mm)
BrakesShimano Deore M6120 4-piston, Shimano RT66 203mm 6-bolt rotorsShimano 4-piston hydraulic disc, M6100 lever, M6120 calliperSRAM CODE Bronze 4-piston hydraulic discSRAM Maven Silver 4-piston hydraulic discSRAM Maven Ultimate 4-piston hydraulic discTektro HD-M745 4-piston hydraulic disc
Rear derailleurShimano XT M8100, long cageShimano XT M8100, long cageSRAM GX Eagle AXS, T-TypeSRAM X0 Eagle AXS, T-TypeSRAM XX Eagle AXS, T-TypeShimano Deore M6100, long cage
CrankE*thirteen E*spec Plus, 165 mm lengthE*thirteen E*spec Plus, 165 mm lengthSram S1000, 165 mm lengthSRAM X0 Eagle, 165 mm lengthSRAM XX Eagle, 165 mm lengthE*thirteen E*spec Plus, 165 mm length
ShiftersShimano SLX M7100, 12-speedShimano XT M8100, 12-speedSRAM AXS podSRAM AXS podSRAM AXS podShimano Deore M6100, 12-speed
CassetteShimano SLX M7100, 10-51T, 12-speedShimano XT M8100, 10-51, 12-speedSRAM Eagle XS-1275, T-Type, 10-52, 12-speedSRAM Eagle XS-1295, T-Type, 10-52, 12-speedSRAM Eagle XS-1297, T-Type, 10-52, 12-speedShimano Deore M6100, 10-51, 12-speed
ChainShimano SLX M7100, 12-speedShimano SLX M7100, 12-speedSRAM GX Eagle, T-Type, 12-speedSRAM X0 Eagle, T-Type, 12-speedSRAM XX Eagle, T-Type, 12-speedShimano Deore M6100, 12-speed
DrivetrainShimano SLX/XT M7100/M8100, 12-speedShimano XT 12-speed; TQ HPR50 (50Nm/250W), 360WhSRAM GX Eagle AXS, T-Type, 12-speedSRAM X0 Eagle AXS, T-Type, 12-speedSRAM XX Eagle AXS, T-Type, 12-speedShimano Deore M6100, 12-speed
WheelsBontrager Line Comp 30, Tubeless Ready, 29"Bontrager Line Comp 30, Tubeless Ready, 29"Bontrager Line Elite 30, OCLV Mountain Carbon, Tubeless Ready, 29"Bontrager Line Pro 30, OCLV Mountain Carbon, Tubeless Ready, 29"Bontrager Line Pro 30, OCLV Mountain Carbon, Tubeless Ready, 29"Bontrager alloy sealed bearing hubs, 6-bolt, Shimano MicroSpline freehub, Boost148
TyresBontrager XR5 Team Issue, Tubeless Ready, Inner Strength casing, aramid bead, 60 tpi, 29x2.50"Bontrager XR5 Team Issue, Tubeless Ready, Inner Strength casing, aramid bead, 60 tpi, 29x2.50"Bontrager SE5 Team Issue, Tubeless Ready, Core Strength sidewalls, aramid bead, 60 tpi, 29x2.50"Bontrager SE5 Team Issue, Tubeless Ready, Core Strength sidewalls, aramid bead, 60 tpi, 29x2.50"Bontrager SE5 Team Issue, Tubeless Ready, Core Strength sidewalls, aramid bead, 60 tpi, 29x2.50"Bontrager XT3 Elite, wire bead, 60 tpi, 29 x 2.40"
Weight19.1 kg20.28 kg18.98 kg18.93 kg18.98 kg20.98 kg
Price£3,195£5,500£9,199£9,600£11,000
Rides similarly
Spot a mistake?
