Bike Finder · Scott
Scott Ransom eRIDE
Scott
Ransom eRIDE 2023
DiscontinuedFull Power · GravityLegacy · 1/10iFreshness 1/10
Big-travel alloy enduro built for steep, sustained descending
Travel F/R
180/180mm
Wheels
29F / 29R
Frame
Aluminium
Weight
24.6 kg
Price
From £5,999
View the Scott Ransom eRIDE on Scott’s site
Scott Ransom eRIDE 2023
From £5,999
EMTB Forums verdict
The 2023 Scott Ransom eRIDE was the brand's full-power enduro e-bike, built around an alloy Horst-link frame with 180mm of travel front and rear and a Bosch Performance Line CX Gen 4 motor (85Nm) fed by an integrated 625Wh PowerTube. A flip-chip at the upper shock mount switched between high and low geometry and allowed a mullet or full 27.5in conversion, giving a slack 64 degree head angle and notably long 465mm chainstays for stability at speed.
Two trims were offered. The flagship 910 (around 6,999 GBP) paired a Fox 38 Performance Elite fork and Fox Float X2 shock with Shimano XT four-piston brakes and a SRAM X01/NX Eagle mix, claiming 24.6kg. The 920 (around 5,999 GBP) swapped to a RockShox ZEB fork, Shimano SLX brakes and a full Shimano XT/Deore 12-speed drivetrain at a claimed 24.8kg. Both ran Syncros finishing kit, Syncros MD30 rims on Formula hubs and a Maxxis Assegai/Dissector tyre pairing in 29 x 2.6in.
It climbs comfortably thanks to the steep seat angle and long rear centre, and descends with the composure you would expect of a 180mm enduro sled, though reviewers flagged the lighter EXO+ casing tyres as a limit on grip in the rough. This model year is now discontinued, superseded by the later 2024/2025 Ransom eRIDE generation.
Geometry read
Size
Descending
83
Slack 64° head angle, 180mm travel and a long 1287mm wheelbase — composed in the chunk, confident when it gets steep, and stable through fast corners.
Playfulness
48
Size balance
97
Rear-long with a planted front in L (FC:RC 1.77) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
76
Bosch Performance Line CX Gen 4 and a steep 76.1° seat angle keep the weight planted over the front — a proper winch. 600W of peak power and 85Nm of torque — a strong full-power motor.
Best suited toFast, steep, rough tracks — and riders who want maximum composure.
Rewards commitment; it should feel calmer as the speed rises.
How it stacks up vs other Full Power · Gravity bikes (from 135 bikes in the database)
Weight24.6 kg0.8 kg heavier than average
Battery625 Wh84 Wh below average
Motor torque85 Nm16 Nm below average
Value for money36/100from £5,999 · most Bosch Performance Line CX Gen 4 bikes ~£5,499
💬 Forum discussion
Scott Ransom eRide 920 battery rattle
9 replies · 6.1k views · last reply 42 months ago
Join the discussion →
Bike geometry diagram
SMLXL
Reach415 mm440 mm470 mm500 mm
Stack644.4 mm644.4 mm649 mm649 mm
Seattube470 mm
Chainstay465 mm465 mm465 mm465 mm
Headtube Angle64°64°64°64°
Seattube Angle (eff)76.5°76.3°76.1°75.9°
Wheelbase1230.3 mm1255.3 mm1287.5 mm1317.5 mm
Headtube120 mm120 mm125 mm125 mm
BB Height353.5 mm353.5 mm353.5 mm353.5 mm
Standover762 mm766 mm790 mm800 mm
Front Centre765.3 mm*790.3 mm*822.5 mm*852.5 mm*
FC:RC1.651.701.771.83
Trims · 2
920
£5,999
910
£6,999
MotorBosch Performance Line CX Gen 4 · 85 Nm · all trims
BatteryBosch PowerTube 625 · 625 Wh · all trims
Travel F/R180/180 mm · all trims
FrameAlloy · all trims
ForkRockShox ZEB Air, 180mmFox 38 Performance Elite Air, Grip2, 180mm
ShockFox Float X2 Performance Air, LSC/LSR with 2-Pos Lever, 180mm · all trims
HeadsetAcros BlockLock Tapered Headset · all trims
StemSyncros XM 1.5 Alloy Stem, 31.8mmSyncros XM1.5 Alloy Stem, 31.8mm
HandlebarSyncros Hixon 2.0 Alloy, Double Butted, 20mm rise, 800mmSyncros Hixon 1.5 Alloy, Double Butted, 20mm rise, 800mm
SaddleSyncros Tofino 2.0Syncros Tofino 1.5 Titanium Rails
SeatpostSyncros Duncan 2.5, Remote, 31.6mmFox Transfer Dropper, Remote, 31.6mm
BrakesShimano SLX M7120 4-Piston, 203mm rotors (front and rear)Shimano XT M8120 4-Piston, 203mm rotors (front and rear)
Rear derailleurShimano XT, 12-SpeedSram X01 Eagle, 12-Speed
ShiftersShimano M6100, 12-SpeedSram NX Eagle, Single Click, 12-Speed
CassetteShimano CS-M6100, 10-51t, 12-SpeedSram XG1275, 11-52t, 12-Speed
ChainShimano CN-M6100, 12-SpeedSram NX Eagle, 12-Speed
DrivetrainShimano XT, 12-Speed; Shimano M6100, 12-Speed; Shimano CS-M6100, 10-51t, 12-Speed; Shimano CN-M6100, 12-SpeedSram X01 Eagle, 12-Speed; Sram NX Eagle, Single Click, 12-Speed; Sram XG1275, 11-52t, 12-Speed; Sram NX Eagle, 12-Speed
WheelsSyncros MD30 30mm rims TL Ready on Formula Hubs · all trims
TyresMaxxis Assegai Front, Maxxis Dissector Rear, 29 x 2.6" · all trims
Weight24.8 kg24.6 kg
Price£5,999£6,999
Rides similarly
Spot a mistake?
