Bike Finder · Santa Cruz
Santa Cruz Vala AL
Santa Cruz
Vala AL 2027
CurrentFull Power · Trail🔥 Hot · 9.2/10iFreshness 9.2/10
Travel F/R
160/150mm
Wheels
MX (29F / 27.5R)
Frame
Aluminium
Weight
Price
From £4,899
View the Santa Cruz Vala AL on Santa Cruz’s site
Santa Cruz Vala AL 2027
From £4,899
Geometry read
Size
Setting
Descending
76
Slack 63.9° head angle, 150mm travel and a long 1269mm wheelbase — composed in the chunk, confident when it gets steep, and stable through fast corners.
Playfulness
55
Size balance
82
Balanced front-to-rear in L (FC:RC 1.86) — weight sits evenly between the wheels.
Technical climbing
72
Bosch Performance Line CX Gen 5 and a steep 77.2° seat angle keep the weight planted over the front — a proper winch. 750W of peak power and 120Nm of torque — among the most powerful e-bike motors made.
Best suited toBig-day all-rounders who climb a lot and still descend hard.
Strong up and composed down — a do-it-all, not a specialist.
How it stacks up vs other Full Power · Trail bikes (from 223 bikes in the database)
Battery600 Wh106 Wh below average
Motor torque120 Nm21 Nm above average
Value for money50/100from £4,899 · most Bosch Performance Line CX Gen 5 bikes ~£4,899
⚙️ Adjustable geometry: this frame has a high/low setting — low drops the BB and slackens the head angle for more descending stability; high lifts the BB and steepens slightly for clearance and a perkier, more playful feel.
💬 Forum discussion
Santa Cruz Vala
862 replies · 206.3k views · last reply today
Join the discussion →
“Got mine last week switched the cranks to raceface era, have a trail cushcore in the front and a emtb one on the rear with pedals, sealant and cushcore comes in at 22kg rides like a dream and the new motors superb and so quiet on descents”
— Davidh218 · ♥ 14 · most-liked post
OWNERS’ REPORT
Santa Cruz Vala — what owners actually know
1,516 posts · 314 owners · data through Jun 2026
3Motor-mount bushing/bolt play and creak (early production - the Vala chapter of the Gen 5 mount issue) · typical onset: First rides to first months (2024-mid 2025 production)
2SRAM Maven feel/maintenance complaints (spec-level) · typical onset: Ongoing maintenance pattern
2Stock radial tyres fold for heavier/harder riders · typical onset: First hard cornering
'The Vala is the superior bicycle, especially in XL/XXL sizes' - from a rider who left Orbea and Transition over build-quality frustrations and 'went back to…
Inside: the community setup plate · numbered field notes · the used-buyer checklist.
Read the full owners’ report →
Bike geometry diagram
Flip-chip position
geometry changes with the chip
SMLXL
Toptube574 mm602 mm623 mm646 mm
Reach435 mm459 mm480 mm500 mm
Stack623 mm633 mm641 mm654 mm
Seattube380 mm400 mm420 mm460 mm
Chainstay439 mm440 mm443 mm446 mm
Headtube Angle64.2°64.2°64.2°64.2°
Seattube Angle (eff)77.2°77.2°77.2°77.2°
Wheelbase1211 mm1242 mm1269 mm1298 mm
Headtube110 mm120 mm130 mm145 mm
BB Height344 mm344 mm344 mm344 mm
Front Centre771 mm801 mm825 mm851 mm
FC:RC1.761.821.861.91
Trims · 2
Deore
£4,899
70
£5,599
MotorBosch Performance Line CX Gen 5 · 120 Nm · all trims
Battery600 Wh · all trims
Travel F/R160/150 mm · all trims
FrameAluminium · all trims
ForkRockShox Psylo Gold RC, 160mmRockShox Zeb Base, 160mm
ShockRockShox Deluxe Select, 205x60RockShox Super Deluxe Base, 205x60
HeadsetFSA IS-2 No.42/ACB · all trims
StemOneUp Enduro Stem, 42mm · all trims
HandlebarSanta Cruz Aluminum Bar, 35x800, 30mm rise · all trims
GripsSanta Cruz House · all trims
SaddleWTB Silverado · all trims
SeatpostSDG Tellis Dropper, 31.6 · all trims
BrakesShimano Deore M6120SRAM DB8
Rear derailleurShimano Deore M6100 SGS, 12spdSRAM 70 Eagle T-Type, 12spd
Cranke*thirteen Helix e*spec, 160mm · all trims
ShiftersShimano Deore SL-M6100 Rapidfire+SRAM Eagle 70 Transmission shifter (single-click)
CassetteShimano Deore M6100, 10-51tSRAM XS-1270 Eagle T-Type, 10-52t
ChainShimano Deore M6100, 12spdSRAM 70 Eagle T-Type Flattop, 12spd
DrivetrainShimano Deore M6100SRAM Eagle 70 Transmission (cable)
WheelsWTB ST Tough 30Reserve 30|HD AL
TyresFront: Maxxis Assegai 29"x2.5" EXO+ / Rear: Maxxis Minion DHRII 27.5"x2.5" DoubleDownFront: Maxxis Assegai 29"x2.5" 3C MaxxGrip EXO+ / Rear: Maxxis Minion DHRII 27.5"x2.5" 3C MaxxTerra DoubleDown
Price£4,899£5,599
Rides similarly
Spot a mistake?
