A solid all-round descender (65° head angle, 170mm) — capable in the rough and steep without being an all-out bruiser.
Level 2022
Long-travel alloy enduro with extreme geometry for steep terrain
The 2022 Mondraker Level is the Spanish brand's full-fat gravity eMTB: 170mm of rear travel from the Zero Suspension System, a 180mm fork up front, and 29in wheels wrapped in DH-casing Maxxis Assegai tyres. Coil shocks on both trims and Mondraker's long, low Forward Geometry mark it out as a bike built to be pointed downhill and held on with intent, not a do-everything trail machine.
Power comes from a Bosch Performance Line CX Gen 4 motor (85Nm) fed by a 750Wh PowerTube, so range and grunt are never the limiting factor. The two-trim range splits on suspension pedigree. The Level R runs a Fox 38 fork and Fox DHX2 coil shock on an alloy Stealth Evo frame at £5,999. The Level RR steps up to a fully adjustable Ohlins RXF38 M.2 fork and Ohlins TTX22M coil, plus a higher-end SRAM build, at £7,999.
It is a burly, deliberate bike. Test weights sat around 27kg for the R and roughly 26kg for the RR, which tells you this was never chasing lightness. Now discontinued and superseded by later Smart System Levels, the 2022 car remains a genuine bike-park and enduro weapon for riders who want coil compliance and DH rubber as standard.
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Balanced front-to-rear in L (FC:RC 1.84) — weight sits evenly between the wheels.
Climbs well — a 76.5° seat keeps the front planted. 600W of peak power and 85Nm of torque — a strong full-power motor.
How it stacks up vs other Full Power · Gravity bikes (from 135 bikes in the database)
| S | M | L | XL | |
| Reach | 450 mm | 470 mm | 490 mm | 510 mm |
| Stack | 632 mm | 632 mm | 652 mm | 652 mm |
| Seattube | 380 mm | 420 mm | 450 mm | 490 mm |
| Chainstay | 455 mm | 455 mm | 455 mm | 455 mm |
| Headtube Angle | 65° | 65° | 65° | 65° |
| Seattube Angle (eff) | 76.5° | 76.5° | 76.5° | 76.5° |
| Wheelbase | 1250 mm | 1270 mm | 1290 mm | 1310 mm |
| Headtube | 110 mm | 110 mm | 130 mm | 130 mm |
| BB Height | 357 mm | 357 mm | 357 mm | 357 mm |
| Front Centre | 795 mm* | 815 mm* | 835 mm* | 855 mm* |
| FC:RC | 1.75 | 1.79 | 1.84 | 1.88 |
Trims · 2
Level R £5,999 | Level RR £7,999 | |
| Motor | Bosch Performance Line CX Gen 4 · 85 Nm · all trims | |
| Battery | Bosch PowerTube 750 · 750 Wh · all trims | |
| Travel F/R | 180/170 mm · all trims | |
| Frame | Level 6061 Alloy Stealth Evo, e-Bike Optimized Zero Suspension System, 170mm travel, Forward Geometry, internal battery, Boost 12x148mm rear axle, tapered head tube, one-piece Monoblock upper link, HHG internal cable routing, MAX capacity sealed bearings, oversize 17mm axles, integrated dropout speed sensor, exclusive plastic motor covers | Level 6061 Alloy Stealth Evo, e-Bike Optimized Zero Suspension System, 170mm travel, Forward Geometry, internal battery with integrated alloy cover, Boost 12x148mm rear axle, tapered head tube, one-piece Monoblock upper link, HHG internal cable routing, MAX capacity sealed bearings, oversize 17mm axles, integrated dropout speed sensor, exclusive plastic motor covers |
| Fork | Fox 38 29 Float FIT GRIP EVOL Performance, 180mm, e-bike tuned, tapered steerer tube, Boost 15x110mm axle, 44mm offset. Settings: 3 positions with micro adjust compression, low-speed rebound, air preload | Öhlins RXF 38 M.2 29, 180mm, TTX18 Twin Tube cartridge, tapered steerer tube, Boost 15x110mm axle, offset 44mm. Settings: high speed compression lever with climb mode, low-speed compression, rebound, air preload, ramp chamber |
| Shock | Fox DHX2 Performance Elite, 225x75mm. Settings: low-speed compression, low-speed rebound, spring preload. Trunnion top mount, 25x10mm bottom bushings | Öhlins TTX22M 225x75mm. Settings: high speed compression lever with climb mode, low-speed compression, rebound, spring preload. Trunnion top mount, 25x10mm bottom bushings |
| Headset | Onoff Saturn tapered for 1-1/8” to 1-1/2” head tube, ACB sealed bearings, top 41x30.2x7x45ºx45º, bottom 51.9x40x8x45ºx45º · all trims | |
| Stem | Onoff Sulfur FG 30mm 0º, 6061 forged alloy, 31.8mm barbore | Onoff Krypton FG 30mm, CNC, 31.8mm barbore |
| Handlebar | Onoff Sulfur 1.0 double butted 6061 alloy, rise: 20mm, width: 800mm, 9º backsweep, 5º upsweep, 31.8mm barbore | Onoff Krypton Carbon 1.0, rise: 25mm, width: 800mm, 9º backsweep, 5º upsweep, 31.8mm barbore |
| Grips | Onoff Diamond, 1lock-on, 135mm · all trims | |
| Saddle | FIZIK Terra Aidon X5 145mm · all trims | |
| Seatpost | Onoff Pija dropper internal, diameter 31.6mm, S size: 387x125mm, M size: 425x150mm, L/XL size: 465x170mm · all trims | |
| Brakes | Front: SRAM G2 RS, oversized 4-piston caliper, Centerline 220mm IS 6 bolts one-piece rotor, organic pads, Rear: SRAM G2 RS, oversized 4-piston caliper, Centerline 220mm IS 6 bolts one-piece rotor, organic pads | Front: SRAM G2 RSC, 4-piston caliper, Centerline 220mm IS 6 bolts one-piece rotor, steel-backed organic pads, Rear: SRAM G2 RSC, 4-piston caliper, Centerline 200mm IS 6 bolts one-piece rotor, steel-backed organic pads |
| Rear derailleur | SRAM GX Eagle, Type 3 roller bearing clutch, cage lock, 1x12s, X-Actuation 1:1 | SRAM X01 Eagle, Type 3 roller bearing clutch, cage lock, 1x12s, X-Actuation 1:1 |
| Crank | Race Face Aeffect ebike, 165mm, Rings: SRAM X-Sync 2 Eagle 34T, steel, narrow-wide, 104 BCD · all trims | |
| Shifters | SRAM Trigger NX Eagle, 12s, X-Actuation 1:1, single click | SRAM Trigger GX Eagle, 12s, X-Actuation 1:1, single click |
| Chain | SRAM SX Eagle, 12s, Powerlock | SRAM GX Eagle, 12s, Powerlock |
| Drivetrain | SRAM GX Eagle, Type 3 roller bearing clutch, cage lock, 1x12s, X-Actuation 1:1; Race Face Aeffect ebike, 165mm, Rings: SRAM X-Sync 2 Eagle 34T, steel, narrow-wide, 104 BCD; SRAM Trigger NX Eagle, 12s, X-Actuation 1:1, single click; SRAM SX Eagle, 12s, Powerlock | SRAM X01 Eagle, Type 3 roller bearing clutch, cage lock, 1x12s, X-Actuation 1:1; Race Face Aeffect ebike, 165mm, Rings: SRAM X-Sync 2 Eagle 34T, steel, narrow-wide, 104 BCD; SRAM Trigger GX Eagle, 12s, X-Actuation 1:1, single click; SRAM GX Eagle, 12s, Powerlock |
| Wheels | Mavic E-Deemax 29, 30mm internal width, welded, PFP, tubeless ready, 28 spokes | e*thirteen E*Spec Plus, IW30 Hookless, 6069 Welded Aluminum 30mm internal width, tubeless ready, 28F / 32R spokes |
| Tyres | Front: Maxxis Assegai 29x2.5WT, tubeless ready, 3C MAXX GRIP compound, DH casing, 60x2TPI, folding bead, Rear: Maxxis Assegai 29x2.5WT, tubeless ready, 3C MAXX GRIP compound, DH casing, 60x2TPI, folding bead · all trims | |
| Weight | 27.27 kg | 25.9 kg |
| Price | £5,999 | £7,999 |
Rides similarly
Spot a mistake?
