A solid all-round descender (65.8° head angle, 140mm) — capable in the rough and steep without being an all-out bruiser.
Trance X Advanced E+ 2023
The Trance X Advanced E+ was Giant's full-power, long-range carbon trail E-MTB for 2023, sitting above the lightweight 400Wh Advanced E+ Elite in the range. It pairs a full Advanced-grade composite frame with 140mm of Maestro rear travel and a 150mm fork, on a full 29in wheel setup, and is built around the large 800Wh EnergyPak battery and the full-power SyncDrive Pro2 motor (85Nm, co-developed with Yamaha). That big battery is the defining difference from the Elite: more range and a heavier bike rather than the Elite's lighter, smaller-battery focus.
Two trims were sold in the UK off one frame. The Advanced E+ 1 at £7,999 was the flagship, with a Fox 36 Performance Elite Live Valve fork and Float X shock, Shimano Deore XT four-piston brakes on 220mm rotors, an XT 12-speed drivetrain and e-TRX carbon wheels. The Advanced E+ 2 stepped down to a Fox 36 Float Performance fork and DPS shock, Shimano SLX brakes on 203mm rotors and Giant AM alloy wheels, keeping the same frame, 800Wh battery and SyncDrive Pro2 motor.
A halo Advanced E+ LTD also existed, listed in the US at 15,000 US dollars, with a Fox 36 Factory Live Valve fork and Float X shock, SRAM XO1 Eagle AXS wireless shifting, Code RSC brakes, a SRAM Reverb AXS dropper and Zipp 3ZERO MOTO carbon wheels. A UK RRP for the LTD could not be confirmed.
Geometry is adjustable via a flip chip giving a slacker, lower Low setting (around 65.7 to 65.8 degrees head angle, 30mm BB drop) and a steeper, higher High setting (66.5 degrees, 20mm BB drop). Reach on a size L runs 482mm Low to 489mm High and chainstays are a long 473mm across all sizes, reflecting the bigger battery and full-power motor packaging. This generation is now discontinued and appears at clearance pricing.
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Rear-long with a planted front in L (FC:RC 1.68) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Giant SyncDrive Pro2 and a steep 76° seat angle keep the weight planted over the front — a proper winch. 250W of peak power and 85Nm of torque — a strong full-power motor.
Strong up and composed down — a do-it-all, not a specialist.
Brilliant on fast, rough, steep terrain; less fun on tight, mellow trails.
How it stacks up vs other Full Power · Trail bikes (from 245 bikes in the database)
| S | M | L | XL | |
| Reach | 447 mm | 462 mm | 489 mm | 517 mm |
| Stack | 601 mm | 605 mm | 614 mm | 624 mm |
| Seattube | 400 mm | 425 mm | 450 mm | 475 mm |
| Chainstay | 473 mm | 473 mm | 473 mm | 473 mm |
| Headtube Angle | 66.5° | 66.5° | 66.5° | 66.5° |
| Seattube Angle (eff) | 78° | 76.7° | 76.7° | 76.7° |
| Wheelbase | 1221 mm | 1237 mm | 1269 mm | 1301 mm |
| Headtube | 95 mm | 100 mm | 110 mm | 120 mm |
| Standover | 746 mm | 734 mm | 726 mm | 723 mm |
| Front Centre | 748 mm* | 764 mm* | 796 mm* | 828 mm* |
| FC:RC | 1.58 | 1.62 | 1.68 | 1.75 |
Trims · 3
Advanced E+ 1 £7,999 | Advanced E+ 2 £0 | Advanced E+ LTD £0 | |
| Motor | Giant SyncDrive Pro2 · 85 Nm · all trims | ||
| Battery | Giant EnergyPak 800 · 800 Wh · all trims | ||
| Travel F/R | 150/140 mm · all trims | ||
| Frame | Advanced-grade composite frame, Advanced-grade rear triangle, Advanced forged composite upper rocker, 140mm Maestro suspension system, 'Boost' 148x12 UDH rear axle, Giant EnergyPak Plus Range Extender Compatible · all trims | ||
| Fork | Fox 36 Performance Elite Live Valve E-Tuned, 29er, 150mm travel, 44mm offset, Fit4 damper, Kabolt-X 110, electronic adaptive suspension, e-bike integrated | Fox 36 Float Performance E-Tuned, 29er, 150mm travel, 44mm offset, Grip 3-position Micro Adjust damper, Kabolt-X 110 | Fox 36 Factory Live Valve, 150mm travel, 44mm offset, Boost 110x15QR, electronic adaptive suspension, E-bike integrated |
| Shock | Fox Float X Performance Elite Live Valve, 185x52.5mm Trunnion mount, electronic suspension, e-bike integrated | Fox DPS Performance, EVOL Large Volume sleeve, 3-position Lever, 185x52.5mm Trunnion mount, custom tuned | Fox Float X Factory Live Valve, 185x52.5mm Trunnion mount, electronic suspension, E-bike integrated |
| Stem | Giant Contact SL 35 | Giant Contact SL 35 | Giant Contact SLR Trail Integrated, Advanced Composite, 5-position adjustable, 40/45/50mm Reach, +3/0/-3 deg Adjust System |
| Handlebar | Giant Contact SL 35, 35x780mm | Giant Contact 35 Trail, 35x780mm | Giant Contact SLR Trail Integrated, Advanced Composite, 5-position adjustable, 800mm (760mm minimum cut width), 7/8/9 deg Back Sweep adjust system, meets DH test standard, GPS mount included |
| Grips | Giant Tactal Pro-E, single lock-on | Giant Tactal Pro-E, single lock-on | Giant Tactal Pro-E, single lock-on, tapered design, Integrated for Ergo3 remote button left or right (optional) |
| Saddle | Giant Romero, Neutral | Giant Romero, Neutral | Giant Romero SL, Neutral |
| Seatpost | Tranz-X Rad+ dropper, 30.9mm, 30mm travel adjustable (S:120-150mm, M:140-170mm, L/XL:170-200mm) | Giant Contact Switch, dropper, 30.9mm (S:125/M:150/L&XL:170) | SRAM Reverb AXS, dropper, 30.9mm (S:125, M:150, L/XL:170) |
| Brakes | Shimano Deore XT, BR-M8120, 4-piston, hydraulic disc, 220mm | Shimano SLX, BR-M7120, 4-piston, hydraulic disc, 203mm | SRAM Code RSC, 4-piston, hydraulic disc, 220mm[F] / 200mm[R] |
| Rear derailleur | Shimano Deore XT, 12-speed, Shadow+ | Shimano Deore SLX, 12-speed, Shadow+ | SRAM XO1 Eagle AXS wireless electronic shifting |
| Crank | Praxis Wave 36T Cold Forged 4130 premium steel, Praxis e-Cadet+ custom forged crankarm set (S:160mm, M/L: 165mm, XL:170mm) | Praxis Wave 36T Cold Forged 4130 premium steel, Praxis e-Cadet+ custom forged crankarm set (S:160mm, M/L: 165mm, XL:170mm) | Praxis Performance Carbon e-crank arms, SRAM X-SYNC Eagle 36T chain ring |
| Shifters | Shimano Deore XT | Shimano Deore SLX | SRAM AXS Rocker Paddle, wireless electronic shifting |
| Cassette | Shimano CS-M7100, 10-51T, 12-speed | Shimano CS-M6100, 10-51T, 12-speed | SRAM XG 1299 Eagle, 10-52T, 12-Speed |
| Chain | KMC e.12 Turbo, EcoProteq, e-bike optimised | KMC e.12 Sport, NP/NP, e-bike optimised | SRAM XX1 Eagle PowerLock, 12-Speed |
| Drivetrain | Shimano Deore XT, 12-speed, Shadow+; Praxis Wave 36T Cold Forged 4130 premium steel, Praxis e-Cadet+ custom forged crankarm set (S:160mm, M/L: 165mm, XL:170mm); Shimano Deore XT; Shimano CS-M7100, 10-51T, 12-speed; KMC e.12 Turbo, EcoProteq, e-bike optimised | Shimano Deore SLX, 12-speed, Shadow+; Praxis Wave 36T Cold Forged 4130 premium steel, Praxis e-Cadet+ custom forged crankarm set (S:160mm, M/L: 165mm, XL:170mm); Shimano Deore SLX; Shimano CS-M6100, 10-51T, 12-speed; KMC e.12 Sport, NP/NP, e-bike optimised | SRAM XO1 Eagle AXS wireless electronic shifting; Praxis Performance Carbon e-crank arms, SRAM X-SYNC Eagle 36T chain ring; SRAM AXS Rocker Paddle, wireless electronic shifting; SRAM XG 1299 Eagle, 10-52T, 12-Speed; SRAM XX1 Eagle PowerLock, 12-Speed |
| Wheels | e-TRX Hookless Carbon Composite Clincher, 29", 30mm inner width | Giant AM 29", Tubeless ready, 30mm inner width, e-bike optimised | Zipp 3ZERO MOTO Carbon |
| Tyres | Maxxis Minion DHF 29x2.6" foldable, Tubeless, EXO+, 3C MaxxTerra [F]; Maxxis Dissector 29x2.6" Foldable, Tubeless, EXO+, 3C MaxxTerra [R] · all trims | ||
| Price | £7,999 | £0 | £0 |
Rides similarly
Spot a mistake?
