Bike Finder · Giant
Giant Trance X Advanced E+ Elite
Giant
Trance X Advanced E+ Elite 2023
DiscontinuedFull Power · TrailLegacy · 0.4/10iFreshness 0.4/10
Motor
Giant SyncDrive Pro2 · 85Nm · 250W
Battery
Giant EnergyPak 400 · 400Wh
Travel F/R
150/140mm
Wheels
MX (29F / 27.5R)
Frame
Advanced-grade composite frame, Advanced-grade rear triangle, Advanced forged composite upper rocker, 140mm Maestro suspension system / Advanced-grade composite frame, Aluxx SL-grade rear triangle, Advanced forged composite upper rocker, 140mm Maestro suspension system
Weight
Price
From £5,499
View the Giant Trance X Advanced E+ Elite on Giant’s site
Giant Trance X Advanced E+ Elite 2023
From £5,499
EMTB Forums verdict
The Trance X Advanced E+ Elite was Giant's lightweight full-power trail E-MTB, built around an Advanced-grade carbon frame with 140mm of Maestro rear travel and a 150mm fork on a mixed 29in front / 27.5in rear wheel setup. Its defining feature was the ultra-slim 2.3kg EnergyPak 400 battery paired with the full-power SyncDrive Pro2 motor (85Nm, co-developed with Yamaha), letting Giant chase a low overall weight without dropping to a reduced-output drive unit. A flip chip gives Low (slacker, lower) and High (steeper, higher) geometry settings.
For 2023 the UK range ran four trims off one frame. The flagship Elite 0 at £12,999 had a Fox 36 Factory Live Valve fork and Float X shock, SRAM XO1 Eagle AXS wireless shifting, Code RSC brakes, a Fox Transfer Factory dropper and carbon Zipp 3MOTO wheels with Quarq Tyrewiz. The Elite 1 at £8,999 used Fox 36 Performance Elite Live Valve suspension, SRAM GX Eagle AXS and Code R brakes on the integrated carbon Contact SLR cockpit. The Elite 2 at £6,499 moved to a Fox 36 Float Performance fork, DPS shock and a full Shimano SLX four-piston build, which is the value sweet spot. The Elite 3 at £5,499 used an Aluxx alloy rear triangle, a RockShox 35 Gold fork and Shimano Deore for the lowest entry price, keeping the same frame, motor and battery.
Geometry is consistent across the range, with a 65.7 to 65.8 degree head angle in Low and 66.5 degrees in High, 447mm chainstays on every size, and reach on a size L running 480mm Low to 487mm High. It is a balanced trail position rather than an outright enduro stance.
This generation is now discontinued and appears at clearance pricing. It remains of interest mainly as a light, carbon, mixed-wheel full-power trail E-MTB for riders who want SyncDrive Pro2 power without a heavy bike, accepting the modest 400Wh battery in exchange for the lower weight.
Geometry read
Size
Setting
Descending
59
A solid all-round descender (65.8° head angle, 140mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
64
Size balance
98
Rear-long with a planted front in L (FC:RC 1.78) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
72
Giant SyncDrive Pro2 and a steep 76° seat angle keep the weight planted over the front — a proper winch. 250W of peak power and 85Nm of torque — a strong full-power motor.
Best suited toBig-day all-rounders who climb a lot and still descend hard.
Strong up and composed down — a do-it-all, not a specialist.
How it stacks up vs other Full Power · Trail bikes (from 245 bikes in the database)
Battery400 Wh304 Wh below average
Motor torque85 Nm13 Nm below average
Value for money50/100from £5,499 · comparable bikes ~£5,499
⚙️ Adjustable geometry: this frame has a high/low setting — low drops the BB and slackens the head angle for more descending stability; high lifts the BB and steepens slightly for clearance and a perkier, more playful feel.
💬 Forum discussion
2026 Giant Reign E+ Megathread
334 replies · 63.5k views · last reply 3 days ago
Join the discussion →
“I saw some rumors & spec sheets circulating on FB about the 2026 Reign E+ so I figured out we could start a thread on here to share informations. Leaked spec sheet below, here's some highlights : New carbon frame available, model is…”
— Redlemon · ♥ 7 · most-liked post
OWNERS’ REPORT
Giant Trance X E+ — what owners actually know
4,937 posts · 792 owners · data through May 2026
10Firmware / derestriction lockouts · typical onset: On any app/firmware update or after fitting a tuning device
8Random shut-off / cut-out (2022-24 Trance X, SyncDrive Pro2) · typical onset: A few hundred miles to 18 months
6Frame cracking at the motor mount / rocker (2022-24 Trance X) · typical onset: 3-12 months
1000 miles through a British winter, completely soaked and muddy, no trouble whatsoever on a 2020 Trance E+ 3, posted to balance a water-ingress thread
Inside: the community setup plate · numbered field notes · the used-buyer checklist.
Read the full owners’ report →
Bike geometry diagram
Flip-chip position
geometry changes with the chip
SMLXL
Reach447 mm462 mm487 mm513 mm
Stack601 mm605 mm619 mm633 mm
Seattube400 mm425 mm450 mm475 mm
Chainstay447 mm447 mm447 mm447 mm
Headtube Angle66.5°66.5°66.5°66.5°
Seattube Angle (eff)78°76.7°76.7°76.7°
Wheelbase1195 mm1212 mm1244 mm1275 mm
Headtube95 mm100 mm115 mm130 mm
Standover735 mm742 mm741 mm750 mm
Front Centre748 mm*765 mm*797 mm*828 mm*
FC:RC1.671.711.781.85
Trims · 4
Elite 3
£5,499
Elite 2
£6,499
Elite 1
£8,999
Elite 0
£12,999
MotorGiant SyncDrive Pro2 · 85 Nm · all trims
BatteryGiant EnergyPak 400 · 400 Wh · all trims
Travel F/R150/140 mm · all trims
FrameAdvanced-grade composite frame, Aluxx SL-grade rear triangle, Advanced forged composite upper rocker, 140mm Maestro suspension systemAdvanced-grade composite frame, Advanced-grade rear triangle, Advanced forged composite upper rocker, 140mm Maestro suspension systemAdvanced-grade composite frame, Advanced-grade rear triangle, Advanced forged composite upper rocker, 140mm Maestro suspension systemAdvanced-grade composite frame, Advanced-grade rear triangle, Advanced forged composite upper rocker, 140mm Maestro suspension system
ForkRockShox 35 Gold RL DebonAir, 150mm travel, 44mm offset, Motion Control rebound and lockout control, 15x110 Boost, Maxle Stealth, e-MTB optimisedFox 36 Float Performance, 150mm travel, 44mm offset, Grip 3-position Micro Adjust damper, Boost 110x15QRFox 36 Performance Elite Live Valve, 150mm travel, 44mm offset, Boost 110x15QR, electronic adaptive suspension, E-bike integratedFox 36 Factory Live Valve, 150mm travel, 44mm offset, Boost 110x15QR, electronic adaptive suspension, e-bike integrated
ShockRockShox Deluxe Select R, DebonAir, 185x52.5mm Trunnion mount, custom tunedFox DPS Performance, EVOL Large Volume sleeve, 3-position Lever, 185x52.5mm Trunnion mount, custom tunedFox Float Performance Elite Live Valve, 185x52.5mm Trunnion mount, electronic suspension, e-bike integratedFox Float X Factory, EVOL, 185x52.5mm Trunnion mount, custom tuned, recommended sag: 30%
StemGiant Contact SL 35Giant Contact SL 35Giant Contact SLR Trail Integrated, Advanced Composite, 5-position adjustable, 40/45/50mm Reach, +3/0/-3 Adjust SystemGiant Contact SLR Trail Integrated, Advanced Composite, 5-position adjustable, 40/45/50mm Reach, +3/0/-3 Adjust System
HandlebarGiant Contact SL 35 Trail, 35x780mmGiant Contact SL 35 Trail, 35x780mmGiant Contact SLR Trail Integrated, Advanced Composite, 5-position adjustable, 800mm, meets DH test standardGiant Contact SLR Trail Integrated, Advanced Composite, 5-position adjustable, 800mm, meets DH test standard
GripsGiant Tactal Pro-E, tapered, 135mm (S/M) 142mm (L/XL), Integrated for Ergo3 remote · all trims
SaddleGiant Romero, NeutralGiant Romero, NeutralGiant Romero, NeutralGiant Romero SL, Neutral
SeatpostGiant Contact Switch dropper, 30.9mm (S:125/M:150/L&XL:170)Giant Contact Switch dropper, 30.9mm (S:125/M:150/L&XL:170)Tranz-X Rad+ dropper, 30.9mm, travel adjustable (S:120-150mm, M:140-170mm, L/XL:170-200mm)Fox Transfer Factory (S:125, M:175, L:150, XL:200)
BrakesShimano BR-M420, 4-piston, hydraulic disc, 203mmShimano SLX BR-M7120, 4-piston, hydraulic disc, 203mm [F/R]SRAM Code R, hydraulic disc, 220mm[F] / 200mm[R]SRAM Code RSC, 4-piston, hydraulic disc, 220mm[F] / 200mm[R]
Rear derailleurShimano Deore 12-speedShimano SLX, 12-speed, Shadow+SRAM GX Eagle AXSSRAM XO1 Eagle AXS
CrankPraxis Wave 36T Cold Forged 4130 premium steel, Praxis e-Cadet+ custom forged crankarm set (S:160, M/L:165, XL:170)Praxis Wave 36T Cold Forged 4130 premium steel, Praxis e-Cadet+ custom forged crankarm set (S:160, M/L:165, XL:170)Praxis Performance Carbon e-crank arms (S:160, M/L:165, XL:170), SRAM X-SYNC Eagle 36T chain ringPraxis Performance Carbon e-crank arms (S:160, M/L:165, XL:170), SRAM X-SYNC Eagle 36T chain ring
ShiftersShimano DeoreShimano SLXSRAM AXS Rocker Paddle, wireless electronic shiftingSRAM AXS Rocker Paddle, wireless electronic shifting
CassetteShimano CS-M6100-12, 10-51T, 12-speedShimano CS-M6100, 10-51T, 12-speedSRAM XG-1275, 10-52T, 12-speedSRAM XG-1299, 10-52T, 12-speed
ChainKMC e.12 Turbo, EcoProteq, e-bike optimisedKMC e.12 Sport, NP/NP, E-bike optimisedSRAM GX Eagle PowerLockSRAM XX1 Eagle Powerlink
DrivetrainShimano Deore 12-speed; Praxis Wave 36T Cold Forged 4130 premium steel, Praxis e-Cadet+ custom forged crankarm set (S:160, M/L:165, XL:170); Shimano Deore; Shimano CS-M6100-12, 10-51T, 12-speed; KMC e.12 Turbo, EcoProteq, e-bike optimisedShimano SLX, 12-speed, Shadow+; Praxis Wave 36T Cold Forged 4130 premium steel, Praxis e-Cadet+ custom forged crankarm set (S:160, M/L:165, XL:170); Shimano SLX; Shimano CS-M6100, 10-51T, 12-speed; KMC e.12 Sport, NP/NP, E-bike optimisedSRAM GX Eagle AXS; Praxis Performance Carbon e-crank arms (S:160, M/L:165, XL:170), SRAM X-SYNC Eagle 36T chain ring; SRAM AXS Rocker Paddle, wireless electronic shifting; SRAM XG-1275, 10-52T, 12-speed; SRAM GX Eagle PowerLockSRAM XO1 Eagle AXS; Praxis Performance Carbon e-crank arms (S:160, M/L:165, XL:170), SRAM X-SYNC Eagle 36T chain ring; SRAM AXS Rocker Paddle, wireless electronic shifting; SRAM XG-1299, 10-52T, 12-speed; SRAM XX1 Eagle Powerlink
WheelsGiant AM 29" [F] / 27.5" [R], Tubeless ready, 30mm inner width, E-bike optimisedGiant AM 29" [F] / 27.5" [R], Tubeless ready, 30mm inner width, E-bike optimisedTRX 2 Hookless Clincher, 29" [F] / 27.5" [R], 30mm inner widthZipp 3MOTO 29" [F] / 27.5" [R], Carbon, with Quarq Tyrewiz
TyresMaxxis Minion DHF 29x2.50" Foldable TLR EXO [F]; Maxxis Dissector 27.5x2.4" Foldable TLR EXO [R]Maxxis Minion DHF 29x2.50" Foldable TLR EXO [F]; Maxxis Dissector 27.5x2.4" Foldable TLR EXO [R]Maxxis Minion DHF 29x2.50" Foldable TLR EXO [F]; Maxxis Dissector 27.5x2.4" Foldable TLR EXO [R]Maxxis Dissector 29x2.40" Foldable TLR EXO [F]; Maxxis Rekon 27.5x2.4" Foldable TLR EXO+ [R]
Price£5,499£6,499£8,999£12,999
Rides similarly
Spot a mistake?
