Bike Finder · Giant
Giant Stance E+
Giant
Stance E+ 2027
CurrentTrail eMTBCurrent · 8.9/10iFreshness 8.9/10
Motor
Giant SyncDrive Pro3 · 100Nm · 800W
Battery
Giant EnergyPak Smart 800 · 800Wh
Travel F/R
150/140mm
Wheels
29F / 29R
Frame
Aluminium
Price
From £3,499
View the Giant Stance E+ on Giant’s site
Giant Stance E+ 2027
From £3,499
EMTB Forums verdict
The Stance E+ is Giant's value-focused full-suspension trail e-MTB, built around an ALUXX SL aluminium frame with the reengineered FlexPoint single-pivot linkage. The 2026 generation steps travel up to 140mm rear and 150mm front from the previous 125/140mm setup, and pairs it with notably modern angles: a 64.5-degree head tube, a steep 76.5-degree seat tube and long 468mm chainstays across every size. Reach runs 431mm (S) to 505mm (XL), giving a stable, planted geometry aimed at fast, steep and technical trails rather than tight, playful flow.
Two motors split the range. The E+ 0 and E+ 1 use the SyncDrive Pro 3X with 100Nm torque and up to 800W peak power, fed by an 800Wh EnergyPak Smart battery, while the cheaper E+ 2 drops to the SyncDrive Sport3 at 85Nm with a 625Wh pack. All three accept the EnergyPak Plus 200Wh or 250Wh range extender, and every battery is removable for off-bike charging.
On value, the E+ 1 at £3,999 is the natural pick of the more powerful pair: it keeps the full-power Pro 3X motor and 800Wh battery of the £4,999 E+ 0, conceding the Fox 36 Rhythm fork and Float X shock for Giant's own STL 36 Air fork and Crest FloTrac shock, plus Deore four-piston brakes and a Cues 10-speed drivetrain in place of the E+ 0's XT mix. The £3,499 E+ 2 is the budget entry, trading the Pro 3X for the Sport3 motor, the smaller 625Wh battery and Tektro Orion brakes, so it makes most sense for riders who do not need the extra torque or range.
💬 Forum discussion
GIANT STANCE E+2 2021
31 replies · 12.4k views · last reply 51 months ago
Join the discussion →
“Got my new bike today. Buzzing. These are like rocking horse ? in the UK right now”
— MrMarzocchi · ♥ 6 · most-liked post
Bike geometry diagram
SMLXL
Reach431 mm455 mm480 mm505 mm
Stack614 mm628 mm641 mm655 mm
Seattube400 mm425 mm450 mm475 mm
Chainstay468 mm468 mm468 mm468 mm
Headtube Angle64.5°64.5°64.5°64.5°
Seattube Angle (eff)76.5°76.5°76.5°76.5°
Wheelbase1229 mm1259 mm1291 mm1322 mm
Headtube100 mm115 mm130 mm145 mm
Standover746 mm744 mm756 mm762 mm
Front Centre761 mm*791 mm*823 mm*854 mm*
Trims · 3
E+ 2
£3,499
E+ 1
£3,999
E+ 0
£4,999
MotorGiant SyncDrive Sport · 85 NmGiant SyncDrive Pro3 · 100 NmGiant SyncDrive Pro3 · 100 Nm
BatteryGiant EnergyPak Smart 800 · 800 Wh · all trims
Travel F/R150/140 mm · all trims
FrameAluminium · all trims
ForkGiant STL 36 Air, 150mm travel, 5-position compression adjust, tapered steerer, 72mm crown, e-bike optimized, 110x15mm Boost axle, full fender compatibleGiant STL 36 Air, 150mm travel, 5-position compression adjust, tapered steerer, 72mm crown, e-bike optimized, 110x15mm Boost axle, full fender compatibleFox 36 Rhythm Air, 150mm travel, Grip damper, 110x15mm thru-axle
ShockGiant Crest FloTrac, 3-position lever, e-bike optimized, 185x52.5mmGiant Crest FloTrac, 3-position lever, e-bike optimized, 185x52.5mmFox Float X, 185x52.5mm
Headset1.5~1.8" headset (ZS62/ZS72) · all trims
StemGiant Contact SL 35 · all trims
HandlebarGiant Connect TR35, 20mm Rise, 35x760mm [S], 35x780mm [M-XL] · all trims
GripsGiant Tactal Pro single lock-on · all trims
SaddleGiant Contact Ergo Trail · all trims
SeatpostGiant Contact Switch AT travel adjust dropper (S:110-140mm, M:140-170mm, L/XL:170-200mm) · all trims
BrakesTektro Orion, hydraulic disc, 4-piston, 203mm [F/R]Shimano Deore, BR-M420, hydraulic disc, 4-piston, 220mm [F] 203mm [R]Shimano Deore XT, BR-M8120, hydraulic disc 4-piston, 220mm [F] 203mm [R]
Rear derailleurShimano Cues LinkGlide, 10-speed, Shadow+Shimano Cues LinkGlide, 10-speed, Shadow+Shimano Deore XT 11-speed Shadow+
CrankForged aluminum crank arms · all trims
ShiftersShimano Cues LinkGlide · all trims
CassetteShimano Cues LinkGlide, 10-speed, 11-48TShimano Cues LinkGlide, 10-speed, 11-48TShimano Cues LinkGlide, 11-speed, 11-50T
ChainShimano LinkGlide · all trims
DrivetrainShimano Cues LinkGlide, 10-speed, Shadow+; Forged aluminum crank arms; Shimano Cues LinkGlide; Shimano Cues LinkGlide, 10-speed, 11-48T; Shimano LinkGlideShimano Cues LinkGlide, 10-speed, Shadow+; Forged aluminum crank arms; Shimano Cues LinkGlide; Shimano Cues LinkGlide, 10-speed, 11-48T; Shimano LinkGlideShimano Deore XT 11-speed Shadow+; Forged aluminum crank arms; Shimano Cues LinkGlide; Shimano Cues LinkGlide, 11-speed, 11-50T; Shimano LinkGlide
WheelsGiant AM30, Tubeless ready, 30mm inner widthGiant AM30, Tubeless ready, 30mm inner widthGiant TRA2, Tubeless ready, 30mm inner width
TyresMaxxis Minion DHF 29x2.50" WT Foldable, TLR, EXO [F]; Maxxis Dissector 29x2.40" WT Foldable TLR EXO [R]Maxxis Minion DHF 29x2.50" WT Foldable, TLR, EXO [F]; Maxxis Dissector 29x2.40" WT Foldable TLR EXO [R]Maxxis Minion DHF 29x2.50" WT Foldable, TLR, EXO, 3C Maxx Terra [F]; Maxxis Dissector 29x2.40" WT Foldable TLR EXO+ [R]
Price£3,499£3,999£4,999
Rides similarly
Spot a mistake?
