Bike Finder · Giant
Giant Stance E+
Giant
Stance E+ 2023
DiscontinuedLightweight · Cross-CountryLegacy · 0.3/10iFreshness 0.3/10
Motor
Giant SyncDrive Sport · 75Nm · 250W
Battery
Giant EnergyPak Smart 625 · 625Wh
Travel F/R
140/125mm
Wheels
29F / 29R
Frame
Aluminium
Weight
25.7 kg
Price
From £3,349
View the Giant Stance E+ on Giant’s site
Giant Stance E+ 2023
From £3,349
EMTB Forums verdict
The Stance E+ is Giant's entry-level full-suspension trail eMTB, built around an ALUXX SL aluminium frame with a single-pivot FlexPoint (flexstay) rear end giving 125mm of travel and a 140mm fork on 29in wheels. It uses Giant's own Yamaha-based SyncDrive Sport motor (75Nm), paired with a removable down-tube EnergyPak and the RideControl Dash display.
The two 2023 trims share the same frame, geometry and motor, differing mainly in fork, brakes and battery. The Stance E+ 1 gets a 625Wh pack, a RockShox 35 Silver fork and a dropper post, while the cheaper Stance E+ 2 runs a 500Wh pack, an SR Suntour XCR fork and a rigid seatpost. Both use a tough Shimano LinkGlide 10-speed drivetrain and grippy Maxxis Minion DHF / Dissector tyres.
Reviewers rated it as a capable, well-priced budget e-MTB with a strong frame and good climbing manners, held back slightly by its weight and modest cassette range. This is a discontinued 2023 model year; the larger-battery E+ 1 carried a £3,999 RRP. Later model years continue the Stance E+ line with revised specifications.
Geometry read
Size
Descending
65
A solid all-round descender (65.5° head angle, 125mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
44
Size balance
84
Rear-long with a planted front in L (FC:RC 1.71) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
73
Giant SyncDrive Sport and a steep 76° seat angle keep the weight planted over the front — a proper winch. 250W of peak power and 70Nm of torque.
Best suited toBig-day all-rounders who climb a lot and still descend hard.
Strong up and composed down — a do-it-all, not a specialist.
How it stacks up vs other Lightweight · Cross-Country bikes (from 63 bikes in the database)
Weight25.7 kg7.1 kg heavier than average
Battery625 Wh189 Wh above average
Motor torque75 Nmclass-leading torque
Value for money32/100from £3,349 · most Giant SyncDrive Sport bikes ~£2,999
💬 Forum discussion
GIANT STANCE E+2 2021
31 replies · 12.4k views · last reply 52 months ago
Join the discussion →
“Got my new bike today. Buzzing. These are like rocking horse ? in the UK right now”
— MrMarzocchi · ♥ 6 · most-liked post
Bike geometry diagram
SMLXL
Reach425 mm450 mm480 mm510 mm
Stack618 mm627 mm636 mm646 mm
Seattube400 mm425 mm450 mm475 mm
Chainstay468 mm468 mm468 mm468 mm
Headtube Angle65.5°65.5°65.5°65.5°
Seattube Angle (eff)76°76°76°76°
Wheelbase1204 mm1233 mm1267 mm1301 mm
Headtube105 mm115 mm125 mm135 mm
BB Height334 mm334 mm334 mm334 mm
Standover760 mm760 mm780 mm796 mm
Front Centre736 mm*765 mm*799 mm*833 mm*
FC:RC1.571.631.711.78
Trims · 2
£3,349
£3,999
MotorGiant SyncDrive Sport · 75 Nm · all trims
BatteryGiant EnergyPak Smart 625 · 625 Wh · all trims
Travel F/R140/125 mm · all trims
FrameAluminium · all trims
ForkSR Suntour XCR 34 LO-R, 140mm travel, tapered steerer, Lockout, 110x15 thru-axleRockShox 35 Silver, 140mm, tapered steerer, 110x15 thru-axle
ShockSR Suntour Raidon R, 190x45mm, recommended sag: 30% · all trims
StemGiant Contact · all trims
HandlebarGiant Connect TR Riser 31.8x780mm · all trims
GripsGiant Tactal single lock-on · all trims
SaddleGiant Sport · all trims
SeatpostGiant 30.9mm, 2-bolt Micro Adjustable, Forged Aluminium (rigid, non-dropper)Giant Contact Switch, dropper, 30.9mm (S:125/M:150/L&XL:170)
BrakesTektro HD-M745 Orion, 4-piston, hydraulic disc, 203mmTektro HD-M750 Orion, 4-piston, hydraulic disc, 203mm
Rear derailleurShimano Deore LinkGlide, 10-speed · all trims
CrankFSA Comet E-Bike crank arm set, FSA MegaTooth Direct-mount 1X steel 36T · all trims
ShiftersShimano Deore LinkGlide · all trims
CassetteShimano LinkGlide, CS-LG400-10, 11-43T, 10-speed · all trims
ChainShimano, LinkGlide, CN-LG500 · all trims
DrivetrainShimano Deore LinkGlide, 10-speed; FSA Comet E-Bike crank arm set, FSA MegaTooth Direct-mount 1X steel 36T; Shimano Deore LinkGlide; Shimano LinkGlide, CS-LG400-10, 11-43T, 10-speed; Shimano, LinkGlide, CN-LG500 · all trims
WheelsGiant AM30, Tubeless ready, 30mm inner width, 29" · all trims
TyresMaxxis Minion DHF 29x2.50" Foldable, TLR, EXO, 60TPI [F] / Maxxis Dissector 29x2.40" WT Foldable, TLR, EXO, 60TPI [R] · all trims
Weight25.7 kg25.8 kg
Price£3,349£3,999
Rides similarly
Spot a mistake?
