Bike Finder · Giant
Giant Stance E+
Giant
Stance E+ 2022
DiscontinuedLightweight · Cross-CountryLegacy · 0.3/10iFreshness 0.3/10
Motor
Giant SyncDrive Sport · 70Nm · 250W
Battery
Giant EnergyPak Smart 625 · 625Wh
Travel F/R
130/120mm
Wheels
29F / 29R
Frame
Aluminium
Weight
Price
From €3,899
View the Giant Stance E+ on Giant’s site
Giant Stance E+ 2022
EMTB Forums verdict
The 2022 Stance E+ is Giant's entry-level full-suspension trail eMTB, built around an ALUXX SL aluminium frame with a single-pivot FlexPoint (flexstay) rear end giving 120mm of travel and a 130mm fork on 29in wheels. It uses Giant's own Yamaha-based SyncDrive Sport motor (70Nm) with 360% tunable support, paired with a removable down-tube EnergyPak and the RideControl display.
Two trims share the same frame, geometry and motor, differing mainly in fork, drivetrain, battery and dropper. The Stance E+ 1 gets a 625Wh battery, a RockShox Recon Silver RL fork, a RockShox Monarch RT shock, a Shimano Deore 12-speed drivetrain (10-51T) and a Giant Contact Switch dropper. The cheaper Stance E+ 2 runs a 500Wh battery, an SR Suntour XCR 34 fork and Edge RC shock, a Shimano Deore 10-speed drivetrain (11-46T) and a rigid seatpost. Both roll on tubeless-ready Giant AM 30mm rims with light EXO-casing Maxxis Rekon 2.4in tyres.
The 2022 geometry is conservative and climbing-focused: a steep 67.0 degree head angle, a 73.5 degree seat angle and long 475mm chainstays, with reach figures from 404mm (S) to 465mm (XL). This is markedly more upright than the slacker 65.5 degree geometry Giant introduced on the later Stance E+, so it favours steady trail riding and climbing over aggressive descending. This is a discontinued 2022 model year; manufacturer pricing was 4,499 euro for the E+ 1 and 3,899 euro for the E+ 2. No published owner ride data is tied specifically to this model year in this dossier, so handling notes above are derived from the geometry and spec rather than test riding.
Geometry read
Size
Descending
46
A solid all-round descender (67° head angle, 120mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
48
Size balance
49
Rear-long with a planted front in L (FC:RC 1.55) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
68
Climbs well — a 73.5° seat keeps the front planted. 250W of peak power and 70Nm of torque.
How it stacks up vs other Lightweight · Cross-Country bikes (from 68 bikes in the database)
Battery625 Wh182 Wh above average
Motor torque70 Nm10 Nm above average
💬 Forum discussion
GIANT STANCE E+2 2021
31 replies · 12.4k views · last reply 52 months ago
Join the discussion →
“Got my new bike today. Buzzing. These are like rocking horse ? in the UK right now”
— MrMarzocchi · ♥ 6 · most-liked post
Bike geometry diagram
SMLXL
Reach404 mm421 mm444 mm465 mm
Stack593 mm603 mm612 mm626 mm
Seattube406 mm432 mm482 mm507 mm
Chainstay475 mm475 mm475 mm475 mm
Headtube Angle67°67°67°67°
Seattube Angle (eff)73.5°73.5°73.5°73.5°
Wheelbase1166 mm1187 mm1213 mm1240 mm
Headtube100 mm110 mm120 mm135 mm
Standover741 mm756 mm788 mm792 mm
Front Centre691 mm*712 mm*738 mm*765 mm*
FC:RC1.451.501.551.61
Trims · 2
€4,499
€3,899
MotorGiant SyncDrive Sport · 70 Nm · all trims
BatteryGiant EnergyPak Smart 625 · 625 Wh · all trims
Travel F/R130/120 mm · all trims
FrameAluminium · all trims
ForkRockShox Recon Silver RL, 130mm travel, Lockout, 110x15mm Boost, Maxle Lite, e-MTB optimisedSR Suntour XCR 34 Air LO-R, 130mm travel, tapered steerer, Lockout, 110x15 thru-axle
ShockRockShox Monarch RT, High Volume, 184x44mm, custom tunedSR Suntour Edge RC
StemGiant Contact · all trims
HandlebarGiant Connect TR Riser 31.8x780mm · all trims
GripsGiant Tactal single lock-on · all trims
SaddleGiant Sport · all trims
SeatpostGiant Contact Switch, dropper, 30.9mm (S:100/M:125/L:150/XL:170)Giant 30.9mm, 2-bolt Micro Adjustable, Forged Aluminium (rigid, non-dropper)
BrakesTektro HD-M745, 4-piston, hydraulic disc, 203mmTektro HD-M745 Orion, 4-piston, hydraulic disc, 203mm
Rear derailleurShimano Deore, 12-speedShimano Deore, 10-speed, Shadow+
CrankForged Alloy minimal Q-factor, 36T Steel Direct Mount ring (S:160, M/L:165, XL:170) · all trims
ShiftersShimano Deore, 12-speedShimano Deore, 10-speed
CassetteShimano CS-M6100-12, 10-51T, 12-speedShimano CS-M4100-10, 11-46T, 10-speed
ChainKMC e.12 Sport, e-bike optimisedKMC e.10 Sport, e-bike optimised
DrivetrainShimano Deore, 12-speed; Forged Alloy minimal Q-factor, 36T Steel Direct Mount ring (S:160, M/L:165, XL:170); Shimano Deore, 12-speed; Shimano CS-M6100-12, 10-51T, 12-speed; KMC e.12 Sport, e-bike optimisedShimano Deore, 10-speed, Shadow+; Forged Alloy minimal Q-factor, 36T Steel Direct Mount ring (S:160, M/L:165, XL:170); Shimano Deore, 10-speed; Shimano CS-M4100-10, 11-46T, 10-speed; KMC e.10 Sport, e-bike optimised
WheelsGiant AM 29", Tubeless ready, 30mm inner width · all trims
TyresMaxxis Rekon 29x2.4" foldable, 60tpi, EXO, Tubeless Ready · all trims
Price€4,499€3,899
Rides similarly
Spot a mistake?
