Bike Finder · Giant
Giant Reign E+
Giant
Reign E+ 2022
DiscontinuedFull Power · EnduroLegacy · 0/10iFreshness 0/10
Motor
Giant SyncDrive Pro · 85Nm · 500W
Battery
Giant EnergyPak Smart 625 · 625Wh
Travel F/R
170/160mm
Wheels
MX (29F / 27.5R)
Frame
Aluminium
Weight
Price
£6,299
View the Giant Reign E+ on Giant’s site
Giant Reign E+ 2022
From £6,299
EMTB Forums verdict
The 2022 Reign E+ is Giant's full-power enduro eMTB, an all-new platform that drops the old freeride numbers for a longer, slacker chassis. It runs 160mm of Maestro rear travel and a 170mm fork on an ALUXX SL aluminium frame with an Advanced Forged Composite upper rocker, and pairs a 29in front wheel with a 27.5in rear (mullet) for a planted yet manoeuvrable feel. A flip-chip swaps between Low and High settings, shifting the head and seat angles by roughly 0.8 degrees and changing the bottom-bracket drop from 25mm to 15mm.
Power comes from Giant's SyncDrive Pro motor (85Nm, co-developed with Yamaha) fed by a downtube-integrated EnergyPak Smart battery, controlled via the RideControl Ergo 3 grip remote and RideControl GO LED console. The flagship E+ 0 carries a larger 750Wh pack, while the E+ 1, E+ 2 and E+ 3 use a 625Wh pack to keep weight and cost down; all are range-extender compatible.
Four aluminium trims spanned the range: the top E+ 0 with Fox Factory 38 and Float X2 plus a SRAM X01 Eagle build, the E+ 1 with Fox Performance Elite suspension and a Shimano XT groupset, the E+ 2 on a RockShox ZEB Select with SRAM GX/NX, and the value E+ 3 on a RockShox Domain with Shimano Deore. Now discontinued (the platform carried into 2023 with the larger 800Wh battery and SyncDrive Pro2 motor), it remains a long-travel, descent-focused enduro eMTB. The E+ 1 launched in the UK at 6,299; other trims were offered at European RRPs of 7,999 (E+ 0), 5,899 (E+ 2) and 5,199 (E+ 3).
Geometry read
Size
Setting
Descending
88
Slack 63.7° head angle, 160mm travel and a long 1265mm wheelbase — composed in the chunk, confident when it gets steep, and stable through fast corners.
Playfulness
38
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Size balance
98
Rear-long with a planted front in L (FC:RC 1.79) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
75
Giant SyncDrive Pro and a steep 76.7° seat angle keep the weight planted over the front — a proper winch. 500W of peak power and 85Nm of torque — a strong full-power motor.
Best suited toFast, steep, rough tracks — and riders who want maximum composure.
Rewards commitment; it should feel calmer as the speed rises.
Watch out forNot a flickable, playful bike — built to plough, not pop.
Brilliant on fast, rough, steep terrain; less fun on tight, mellow trails.
How it stacks up vs other Full Power · Enduro bikes (from 146 bikes in the database)
Battery625 Wh106 Wh below average
Motor torque85 Nm18 Nm below average
Value for money17/100from £6,299 · comparable bikes ~£5,154
⚙️ Adjustable geometry: this frame has a high/low setting — low drops the BB and slackens the head angle for more descending stability; high lifts the BB and steepens slightly for clearance and a perkier, more playful feel.
💬 Forum discussion
2026 Giant Reign E+ Megathread
334 replies · 63.6k views · last reply 4 days ago
Join the discussion →
“I saw some rumors & spec sheets circulating on FB about the 2026 Reign E+ so I figured out we could start a thread on here to share informations. Leaked spec sheet below, here's some highlights : New carbon frame available, model is…”
— Redlemon · ♥ 7 · most-liked post
OWNERS’ REPORT
Giant Reign E+ — what owners actually know
7,171 posts · 705 owners · data through Jun 2026
20Gen 2 (2022): frame 'cracking' at the downtube/motor-mount weld - the cosmetic-filler saga · typical onset: 5-18 months; reports trail into 2025 as low-mileage bikes age
5Rear hub / freehub weakness (Gen 1-2, stock wheels) · typical onset: Weeks to a year, torque-dependent
4Battery, charging and charge-port niggles (Gen 2) · typical onset: Sporadic; winter-correlated
5,000km faultless on a 2022 E+2 - posted specifically to balance a lemon thread
Inside: the community setup plate · numbered field notes · the used-buyer checklist.
Read the full owners’ report →
Bike geometry diagram
Flip-chip position
geometry changes with the chip
SMLXL
Reach430 mm455 mm480 mm505 mm
Stack632 mm632 mm641 mm650 mm
Seattube400 mm425 mm450 mm475 mm
Chainstay454 mm454 mm454 mm454 mm
Headtube Angle64.5°64.5°64.5°64.5°
Seattube Angle (eff)77.5°77.5°77.5°77.5°
Wheelbase1210 mm1237 mm1266 mm1296 mm
Headtube100 mm100 mm110 mm120 mm
Standover789 mm776 mm775 mm772 mm
Front Centre756 mm*783 mm*812 mm*842 mm*
FC:RC1.671.721.791.85
Trims · 4
£6,299
€7,999
€5,899
€5,199
MotorGiant SyncDrive Pro · 85 Nm · all trims
BatteryGiant EnergyPak Smart 625 · 625 Wh · all trims
Travel F/R170/160 mm · all trims
FrameAluminium · all trims
ForkFox 38 Float Performance Elite 29er, 170mm travel, GRIP2 VVC Damper, Boost 110x15 Kabolt floating axle, e-Bike optimisedFox 38 Float Factory 29er, 170mm travel, GRIP2 VVC Damper, Boost 110x15 Kabolt floating axle, with fender, e-Bike optimisedRockShox ZEB Select 29er, 170mm travel, Charger RC damper, 15x110 Boost, Maxle Stealth, E-bike approvedRockShox Domain R 29er, 170mm travel, 15x110 Boost, Maxle Stealth, E-bike Approved
ShockFox Float X2 Performance Elite, EVOL Large Volume sleeve, 2-position lever, 205x62.5mm Trunnion mount, custom tunedFox Float X2 Factory, EVOL Large Volume sleeve, 2-position lever, 205x62.5mm Trunnion mount, custom tunedFox Float DPX2 Performance, EVOL Large Volume sleeve, 2-position lever, 205x62.5mm Trunnion mount, custom tunedFox Float DPS Performance, EVOL Large Volume sleeve, 2-position lever, 205x62.5mm Trunnion mount, custom tuned
StemGiant Contact SL 35 · all trims
HandlebarGiant Contact Trail, 35x800mmGiant Contact Trail SL, 35x800mmGiant Contact Trail, 35x800mmGiant Contact Trail, 35x800mm
GripsGiant Tactal Pro-E, single lock-on · all trims
SaddleGiant RomeroGiant RomeroGiant Romero TrailGiant Romero Trail
SeatpostGiant Contact Switch, dropper, 30.9mm (S:125, M:150, L/XL:170) · all trims
BrakesShimano Deore XT, BR-M8120, 4-piston, hydraulic disc, 203mmSRAM Code RSC, hydraulic disc, 220mm[F] / 200mm[R]SRAM Code R, hydraulic disc, 220mm[F] / 200mm[R]Shimano Deore BR-M4120, 4-piston, hydraulic disc, 203mm
Rear derailleurShimano Deore XT, 12-Speed, Shadow+SRAM XO1 EagleSRAM GX 12-speedShimano Deore 12-speed
CrankPraxis Wave 36T Cold Forged 4130 premium steel, Praxis e-Cadet+ custom forged crankarm set (S/M:160, L/XL:165)SRAM X-Sync Eagle 36T chainring, Praxis e-Carbon custom carbon crankarm set (S/M:160, L/XL:165)SRAM X-Sync Eagle 36T chainring, Praxis e-Cadet+ custom forged crankarm set (S/M:160, L/XL:165)Praxis Wave 36T Cold Forged 4130 premium steel, Praxis e-Cadet+ custom forged crankarm set (S/M:160, L/XL:165)
ShiftersShimano Deore XTSRAM XO1 EagleSRAM NXShimano Deore
CassetteShimano HG-M7100, 10-51T, 12-speedSRAM PG-1230, 11-50T, 12-speedSRAM PG-1230, 11-50T, 12-speedShimano Deore CS-M6100-12, 10-51T, 12-speed
ChainKMC e.12 Sport, EcoProteq, e-bike optimisedSRAM XO1 Eagle PowerLockSRAM NX Eagle PowerLockKMC e.12 Turbo, EcoProteq, e-bike optimised
DrivetrainShimano Deore XT, 12-Speed, Shadow+; Praxis Wave 36T Cold Forged 4130 premium steel, Praxis e-Cadet+ custom forged crankarm set (S/M:160, L/XL:165); Shimano Deore XT; Shimano HG-M7100, 10-51T, 12-speed; KMC e.12 Sport, EcoProteq, e-bike optimisedSRAM XO1 Eagle; SRAM X-Sync Eagle 36T chainring, Praxis e-Carbon custom carbon crankarm set (S/M:160, L/XL:165); SRAM XO1 Eagle; SRAM PG-1230, 11-50T, 12-speed; SRAM XO1 Eagle PowerLockSRAM GX 12-speed; SRAM X-Sync Eagle 36T chainring, Praxis e-Cadet+ custom forged crankarm set (S/M:160, L/XL:165); SRAM NX; SRAM PG-1230, 11-50T, 12-speed; SRAM NX Eagle PowerLockShimano Deore 12-speed; Praxis Wave 36T Cold Forged 4130 premium steel, Praxis e-Cadet+ custom forged crankarm set (S/M:160, L/XL:165); Shimano Deore; Shimano Deore CS-M6100-12, 10-51T, 12-speed; KMC e.12 Turbo, EcoProteq, e-bike optimised
WheelsGiant e-TR1 27.5"/29", Tubeless ready, 30mm inner widthGiant e-TRX 27.5"/29", Tubeless ready, 30mm inner widthGiant AM 29"[F] 27.5"[R], Tubeless ready, 30mm inner widthGiant AM 29"[F] 27.5"[R], Tubeless ready, 30mm inner width
TyresMaxxis Minion DHF 29x2.6" foldable, Tubeless, EXO+, 3C MaxxTerra [F]; Maxxis High Roller II 27.5x2.5" foldable, Tubeless, DoubleDown, 3C MaxxTerra [R] · all trims
Price£6,299€7,999€5,899€5,199
Rides similarly
Spot a mistake?
