A solid all-round descender (68° head angle, 120mm) — capable in the rough and steep without being an all-out bruiser.
Fathom E+ 2022
The 2022 Giant Fathom E+ is the brand's trail-focused hardtail eMTB, built around an ALUXX aluminium frame, 29-inch wheels and a Giant SyncDrive motor co-developed with Yamaha. The UK lineup ran to two trims: the E+ 2 at £2,999 and the E+ 2 Pro at £3,499. It is now discontinued.
The E+ 2 pairs a 70Nm SyncDrive Sport motor with the integrated 500Wh EnergyPak Smart battery, a 120mm SR Suntour XCR 32 coil fork, Shimano Deore 1x10 gearing, Tektro HD-M280 brakes on 180mm rotors and Maxxis Rekon 2.4in tyres. Geometry is fairly conservative at a 68-degree head angle and 73-degree effective seat angle across S to XXL.
The E+ 2 Pro steps up to a 625Wh battery, an 80Nm SyncDrive Pro motor with 360 percent tunable power, a 130mm SR Suntour XCR 34 air fork, a Shimano Deore LinkGlide drivetrain and grippier Maxxis Minion DHF / Aggressor 2.5in tyres. The taller fork slackens the head angle to 66 degrees and steepens the effective seat angle to 76 degrees, giving noticeably longer reach numbers across S to XL on the same frame.
Both trims use a Boost rear end, Giant Connect TR 780mm bars and a fixed (non-dropper) seatpost as standard. As a hardtail there is no rear suspension. Range and ride feel will depend heavily on rider weight, terrain and conditions.
Rear-long with a planted front in L (FC:RC 1.51) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Climbs well — a 73° seat keeps the front planted. 250W of peak power and 70Nm of torque.
How it stacks up vs other Lightweight · Cross-Country bikes (from 65 bikes in the database)
| S | M | L | XL | XXL | |
| Reach | 384 mm | 406 mm | 428 mm | 449 mm | 470 mm |
| Stack | 625 mm | 634 mm | 643 mm | 657 mm | 671 mm |
| Seattube | 405 mm | 455 mm | 505 mm | 535 mm | 560 mm |
| Chainstay | 475 mm | 475 mm | 475 mm | 475 mm | 475 mm |
| Headtube Angle | 68° | 68° | 68° | 68° | 68° |
| Seattube Angle (eff) | 73° | 73° | 73° | 73° | 73° |
| Wheelbase | 1141 mm | 1167 mm | 1193 mm | 1219 mm | 1245 mm |
| Headtube | 105 mm | 115 mm | 125 mm | 140 mm | 155 mm |
| Standover | 723 mm | 753 mm | 788 mm | 808 mm | 828 mm |
| Front Centre | 666 mm* | 692 mm* | 718 mm* | 744 mm* | 770 mm* |
| FC:RC | 1.40 | 1.46 | 1.51 | 1.57 | 1.62 |
Trims · 2
E+ 2 £2,999 | E+ 2 Pro £3,499 | |
| Motor | Giant SyncDrive Sport · 70 Nm | Giant SyncDrive Pro · 70 Nm |
| Battery | Giant EnergyPak Smart 500 · 500 Wh · all trims | |
| Travel F/R | 120/? mm · all trims | |
| Frame | ALUXX Aluminium · all trims | |
| Fork | SR Suntour XCR 32 Coil LO Boost 29 120mm travel, Tapered 1½ - 1⅛" steerer, lockout | SR Suntour XCR 34 Boost Air LOR, 130mm travel, Tapered 1½ - 1⅛" steerer, lockout |
| Headset | Overdrive 1½ - 1⅛" · all trims | |
| Stem | Giant Contact · all trims | |
| Handlebar | Giant Connect TR Riser 31.8x780mm · all trims | |
| Grips | Giant Sole-O Grip | Giant Tactal Lock-On |
| Saddle | Giant Sport · all trims | |
| Seatpost | Giant 30.9mm, 2-bolt Micro Adjustable, Forged Aluminium · all trims | |
| Brakes | Tektro HD-M280, hydraulic disc, 180mm | Tektro HD-M275, hydraulic disc, 180mm [F/R] |
| Rear derailleur | Shimano Deore, 10-speed, Shadow+ | Shimano Deore, 10-speed, LinkGlide, Shadow+ |
| Crank | FSA Comet E-Bike crank arm set, FSA MegaTooth Direct-mount 1X steel 36T | Praxis Wave 36T Cold Forged 4130 premium steel, Praxis e-Cadet+ custom forged crankarm set |
| Shifters | Shimano Deore 1x10 speed | Shimano Deore LinkGlide |
| Cassette | Shimano CS-M4100-10 11-46T 10-speed | Shimano Deore LinkGlide CS-M5130-10, 11-43T, 10-speed |
| Chain | KMC e.10 Sport, e-bike optimised | Shimano, CN-LG500, 9/10/11speed for LinkGlide |
| Drivetrain | Shimano Deore, 10-speed, Shadow+; FSA Comet E-Bike crank arm set, FSA MegaTooth Direct-mount 1X steel 36T; Shimano Deore 1x10 speed; Shimano CS-M4100-10 11-46T 10-speed; KMC e.10 Sport, e-bike optimised | Shimano Deore, 10-speed, LinkGlide, Shadow+; Praxis Wave 36T Cold Forged 4130 premium steel, Praxis e-Cadet+ custom forged crankarm set; Shimano Deore LinkGlide; Shimano Deore LinkGlide CS-M5130-10, 11-43T, 10-speed; Shimano, CN-LG500, 9/10/11speed for LinkGlide |
| Wheels | Giant XCT 29 Tubeless Ready 25mm e-bike optimised | Giant AM 29", Tubeless ready, 30mm inner width |
| Tyres | Maxxis Rekon 29x2.4", EXO, 60 TPI | Maxxis Minion DHF 29x2.5" 60TPI Foldable, TLR EXO [F]; Maxxis Aggressor 29x2.5" 60TPI Foldable TLR EXO [R] |
| Price | £2,999 | £3,499 |
Rides similarly
Spot a mistake?
