Fathom E+ EX 2024
Aluminium hardtail with SyncDrive Pro 2 motor and 800Wh EnergyPak
The Giant Fathom E+ Ex 2024 is an aluminium full-power hardtail eMTB built around Giant's in-house SyncDrive Pro2 motor, pitched as a do-it-all entry-to-mid-level full-power hardtail. Headline numbers: 85 Nm of torque, 800 Wh removable Giant EnergyPak battery, 120 mm of front travel, a 66.0 degree head angle and 24.8 kg claimed. There are no curated community quotes on file yet, so this verdict draws on the gold spec sheet and Giant's broader platform context.
Drive system and range. The SyncDrive Pro2 is Giant's own-brand mid-drive unit, built in partnership with Yamaha, producing 85 Nm of torque and a 600 W manufacturer-claimed peak, at a 2.75 kg motor weight. The 800 Wh EnergyPak battery is removable and is one of the largest packs in this class, paired with the 120 mm front-travel hardtail format which keeps frame weight modest. Real-world range on a hardtail 24.8 kg eMTB with 800 Wh is exceptional — expect long all-day rides comfortably within reach on mixed terrain, and 100 km-plus tours feasible in lower assist modes. The trade-off versus Bosch CX or Shimano EP801 is the smaller dealer network for SyncDrive units outside of Giant's own retail channel, though the motor itself has proven reliable across multiple model generations.
Geometry and handling. The Fathom E+ Ex runs five sizes (S, M, L, XL, XXL), with reach progressing from 416 mm (S) through 446 mm (M), 466 mm (L), 481 mm (XL) and topping out at 486 mm (XXL). The head angle is fixed at 66.0 degrees across the range, which is appropriately conservative for a 120 mm trail-leaning hardtail. The 470 mm chainstay is shared across all sizes — long even by hardtail standards — and the wheelbase grows from 1,197 mm (S) to 1,284 mm (XXL). This is a stable, planted geometry profile that will reward steady climbers and tour-style riding, but feel slow to flick into corners compared to shorter-rear-centre rivals.
Build and value. Only the base trim is on file, with the alloy frame, SyncDrive Pro2 motor, EnergyPak 800 battery and Giant's component spec. Price for the UK market is not listed in the gold facts, but Giant's direct-to-shop distribution typically prices this segment well below carbon full-suspension rivals at equivalent motor and battery specs. Buyers should expect a Shimano-leaning groupset and house-brand wheels at this level.
Verdict. The Giant Fathom E+ Ex 2024 makes sense for the rider who wants a high-capacity 800 Wh battery, a robust full-power motor at 85 Nm, conservative trail-friendly geometry and the Giant dealer network behind them, all on a sensibly-priced alloy hardtail platform. Less suitable for buyers who prioritise aggressive trail handling, full-suspension comfort on rougher terrain, or the very latest Bosch CX Gen 5 / Shimano EP801 motor systems. Production status: current.
| S | M | L | XL | XXL | |
| Reach | 416 mm | 434 mm | 451 mm | 469 mm | 486 mm |
| Stack | 647 mm | 656 mm | 665 mm | 675 mm | 684 mm |
| Chainstay | 470 mm | 470 mm | 470 mm | 470 mm | 470 mm |
| Headtube Angle | 66° | 66° | 66° | 66° | 66° |
| Seattube Angle (eff) | 75° | 75° | 75° | 75° | 75° |
| BB Drop | 65 mm | 65 mm | 65 mm | 65 mm | 65 mm |
| Wheelbase | 1197 mm | 1219 mm | 1241 mm | 1262 mm | 1284 mm |
| Headtube | 110 mm | 120 mm | 130 mm | 140 mm | 150 mm |
| Standover | 730 mm | 757 mm | 750 mm | 773 mm | 776 mm |
| Front Centre | 727 mm | 749 mm | 771 mm | 792 mm | 814 mm |
Trims · 2
Fathom E+ 1 EX £4,199 | EX 2 | |
| Motor | Giant SyncDrive Pro2 · 85 Nm · all trims | |
| Battery | Giant EnergyPak 800 · 800 Wh · all trims | |
| Travel F/R | 120/? mm · all trims | |
| Frame | Aluminium · all trims | |
| Fork | SR Suntour XCR 34 Boost 2-CR Air 29, 130mm travel, tapered 1.125"-1.5" steerer | SR Suntour XCR 34 2-CR Coil, 130mm Federweg, Boost 15x110mm |
| Stem | Giant Contact · all trims | |
| Handlebar | Giant Connect TR Riser 31.8x750mm [S], 780mm [M-XXL] | GIANT Connect TR Riser 31.8, 20mm rise |
| Grips | Giant Tactal Pro, single lock-on | GIANT Tactal single lock-on |
| Saddle | Giant Ergo Contact Trail · all trims | |
| Seatpost | Giant Contact Switch Adj, adjustable dropper, 30.9mm | GIANT 30.9mm |
| Brakes | Shimano Deore, BR-MT410, hydraulic disc, 180mm [F/R] | Tektro HD-M285, 180mm |
| Rear derailleur | Shimano Cues LinkGlide, 11-speed | Shimano Cues LinkGlide, 9-speed |
| Crank | FSA MegaTooth direct-mount 1X steel 36T FSA Comet E-Bike crank arm | FSA Comet, FSA MegaTooth 36T Kettenblatt |
| Shifters | Shimano Cues LinkGlide · all trims | |
| Cassette | Shimano Cues LinkGlide, CL-LG400-11, 11-50T, 11-speed | Shimano Cues, LinkGlide, CS-LG300-9, 11-46T |
| Chain | KMC eGlide NP/BK, e-bike optimized · all trims | |
| Drivetrain | Shimano Cues LinkGlide, 11-speed | Shimano Cues LinkGlide, 9-speed |
| Wheels | Giant eTracker Boost 15x110 [F] 12x148 [R] | GIANT XCT 29" Tubeless Ready 25mm rims, GIANT eTracker hubs, stainless steel spokes |
| Tyres | Maxxis Rekon 29x2.4" Wire Bead 60TPI | Maxxis Rekon 29 x 2.4" wire bead |
| Weight | 25.84 kg | 26.2 kg |
| Price | £4,199 | — |
Rides similarly
Spot a mistake?
